Buying Advice Newbie tractor advice
   / Newbie tractor advice #11
I bought a 22 acre farm property that has rolling, mostly dry fields and currently produces hay and corn.
I have a barn and pasture areas and will be getting some farm animals as hobby farming.
Next spring I will probably take over the fields, but not sure yet what I will focus on growing.
A smaller acreage tractor will not be great in the fields and a larger farming machine will not be great around the barn.
To me an investment in TWO tractors, plus implements, for 22 total acres, less ground for farm animals, would be an extravagance. No chance of ever making the property 'pay', certainly not with hay and corn.
COASTER33: Is this a part time endeavor while you still have a paycheck coming in, or will you be retired with time but not necessarily gushing funds?
   / Newbie tractor advice #12
Pallets would be off flat deck or 5 ton so 5-6 feet
Is there a reason you cannot split your one ton loads into two pallets of 1,000 pounds each? You will need an outsize tractor for this singular 2000#/72" requirement. If you can split the loads into two 1,000 pound pallets you will reduce your tractor cost by half.
A tractor this large may not fit in the barn door, even with the ROPS folded. (Entry height on my little L3560, with the ROPS folded, is 86".) What is the height of your barn door?
So often here: Do not let the PERFECT be the enemy of the GOOD.
   / Newbie tractor advice #13
   / Newbie tractor advice #14
A tractor is never going to be satisfactory for moving one ton pallets regularly, nor particularly safe. Besides the outsize tractor your 2000#/72" requires, the load will make even a big tractor tippy. Water is inherently unstable as a load. The first time a pallet of live fish slides off, how will you feel?
The Right Tool for this requirement is another rear-engine, low ground clearance, Skid Steer; not a tractor.
Hydraulic Breaker (A55973)
Hydraulic Breaker...
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
2017 CATERPILLAR 259D SKID STEER (A52709)
2017 CATERPILLAR...
1999 Dodge Ram1500 ST Ext. Cab Pickup Truck (A56858)
1999 Dodge Ram1500...
2023 BOBCAT T770 SKID STEER (A52709)
2023 BOBCAT T770...
20704 (A55853)
20704 (A55853)
