Tires Newbie questionon loading tires
   / Newbie questionon loading tires #11
When loading tractor tires I ALWAYS have my dealer insert tubes first, then load the tires. The tube keeps whatever liquid is used from actually making ANY contact with the rims, thus no corrosion.A little more expensive but in the long run I think it saves the rims from replacement due to corrosion. Whatever you use, if you don't use tubes inside the tire first, corrosion will play a part in deteriorating the rims over time.
   / Newbie questionon loading tires #12
Dave,
This is a link I used to load the tires. They cover how much to put into the fronts and rears depending whether your pulling or pushing and whether you have 2 or 4wd. How to keep the weight balance and how to check for proper traction.
It was kinda fun doing it myself...learned a lot.
CLICK HERE
   / Newbie questionon loading tires #13
Yes Tubes are a must ,in my book.I run some antifreeze and water.Poormans ballast.
   / Newbie questionon loading tires #14
</font><font color="blue" class="small">( Whatever you use, if you don't use tubes inside the tire first, corrosion will play a part in deteriorating the rims over time. )</font>
If I remember correctly, this is not the case with RimGuard. It actually protects teh rims from corrosion. (But it's been a while since I reviewed the info on the stuff).
John Mc
AUCTION STARTS HERE @ 9AM (A52707)
AUCTION STARTS...
2008 STOUGHTON TRAILER STOUGHTON TRAILER (A55745)
2008 STOUGHTON...
2019 Chevrolet Silverado1500 LD Crew Cab Pickup Truck (A55852)
2019 Chevrolet...
UNUSED FUTURE 36C STAD ON SKID STEER (A57192)
UNUSED FUTURE 36C...
2016 Chevrolet Tahoe SUV (A55853)
2016 Chevrolet...
2014 Ford F-150 Pickup Truck (A55852)
2014 Ford F-150...
