Newbie question
/ Newbie question #1
johngrabo
Oxford NY
kioti CK20HST
Hi all, I did some searching but couldn't find what I was looking for so I figured I would post the question here for some insight.
I have a Kioti CK20HST and bought a Kioti branded 4' brush cutter at the end of last year. (I am told it is the Woods BB48X with slip clutch model private labeled for Kioti). Anyway, I was cutting 10acres of grass field and noticed the shaft separated from the gear box and in looking, found the nylok nut sitting on the top of the mower. The bolt was long gone, but in looking at the nut, it appeared it just came undone.
I looked up the part in the included manual and it states to use a 1/2" nylok nut and 1/2" grade 8 bolt NC. I went to the local supply store and bought what was needed, and reassembled, but found I can not get a wrench or socket on either the bolt or nut due to lack of clearance of the collar. I would up cutting back some of the plastic shield and muscled the bolt on with some red locktite as it didn't seem the bolt was long enough for the nylock to catch,
Are there special bolts to use with an undersized head in order to get a socket on the head of the nut or bolt? I was able to finish up the cutting without issue, but not convinced this is the hot set up for this bolt.
Since it is a grade 8, can I install a longer bolt with some spacers included in order to get a wrench on these heads?
Thanks for your input in advance.
John
/ Newbie question #2
if the bolt isnt long enough to use the nyloc you have the wrong length bolt.
For whatever your doing you do what it takes to get the job done. what you are doing is a very simple fix.
/ Newbie question #3
As suggested your choice of bolt is too short. You can also get a Allen head bolt if clearance is a problem. For the other end you could try a thin wall socket to access the nut. I guess you figured out why it came apart.
/ Newbie question
Weird how the manual says to use a 3" bolt, but it is too short. I will try the hex head bolt route and get one 3-1/2" or 4" and try that. Thank you everyone.
/ Newbie question #5
It depends on how you measured the new bolt.
Bolts are measured by the length of their shank...which does NOT include the thickness of the head. So if you measured a bolt from the top of the head, to the end of the shank like most people do, you would have measured out a "3 inch bolt" but you would have actually been short by about 3/8 to a 1/2 inch. This would account for why the nut would not thread on.
If you bought a bolt according to what was listed on the side of the bin, then it s possible some clerk put the wrong length bolt in the bin.
/ Newbie question #6
I just cut away some of that plastic. You can, and it'll still do what it's supposed to do.
Ralph
INGERSOLL RAND BLAW-KNOX PAVER (A67714)
INGERSOLL RAND...
WESTINGHOUSE PORTABLE ARC WELDER (A64276)
WESTINGHOUSE...
2009 PETERBILT 365(INOPERABLE) (A67714)
2009 PETERBILT...
2012 COMPTANK  ACID TRANSPORT TRAILER (A67714)
2012 COMPTANK...
2019 Peterbilt 579 T/A Wet Kit Day Cab Truck Tractor (A66736)
2019 Peterbilt 579...
BOBCAT 751 SKID STEER (A65053)
BOBCAT 751 SKID...
