newbie problem; alternator warning light
/ newbie problem; alternator warning light #1
jimbobs61
Boston, Alabama
Kubota 3200 with FEL
Hey guys, I just bought a Ford 2600 for cutting and gardening and the only thing working on the panel is the alternator warning light which stays on. It needs all new wiring ( most wires aren't even attached ). Should I take the alternator off and have it checked or redo the wiring? I hope to restore it all eventually but for now I just need to keep it going to bust up some new ground. Yep, the battery goes down when connected, whether it is running or not. Thanks, Jim
/ newbie problem; alternator warning light #2
Redo the wireing = yes
have alt checked = yes.
is it an oem alternator.. or a gm/delco 1/3 wire farmerized on there?
soundguy
Thanks soundguy, I will check on the brand when I get back up to the country. What do I need to know if it is the Delco? Jim
/ newbie problem; alternator warning light #5
Yep.. ditto what rick said... If it's a delco 10SI or 12SI.. you can get them at any parts store for 25-45$.. and they hookup with 3 wires and a light bulb or diode... super simple.. nearly foolproof.. and as rick said.. non oem.
soundguy
Sounds great guys. On the wiring, should I buy the harness and wires as a package or can you just replace individual wires that are attached now. With a hot battery it cranks and runs strong. Jim
/ newbie problem; alternator warning light #7
that's kinda up to you and your electrical ability.. and how much you want to root around in the old harness. If you only have a bad wire or two i don't see why you couldn't piggyback a couple to the harness using zip ties, and then do a bypass... etc.. all depends of your skills.
soundguy
As long as ability doesn't imply knowledge, I'm all over it. I'm gonna wade in and replace what I can see are connected wires that are broken etc. Hopefully I can find a local to lend a hand. Thanks again for the advice.
Jim
2015 CHEVROLET SILVERADO CREW CAB PICKUP TRUCK (A66091)
2015 CHEVROLET...
2001 Freightliner FL112 T/A 5 Car Hauler Truck (A68183)
2001 Freightliner...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
2019 Kenworth T880 Tri-Axle Dump Truck (A61573)
2019 Kenworth T880...
2018 CAT D6TXL DOZER (A67714)
2018 CAT D6TXL...
2017 FORD F550 4X2 S/A SERVICE BODY TRUCK (A67737)
2017 FORD F550 4X2...
