artp
Bronze Member
I tried to use my new box blade to smooth out a small area (80 X 200ft) in the back of my property that was rather rough and uneven so I could more easily use my new finish mower to maintain the property. I first set the rippers at maximum depth thinking that I needed to get down that deep. After working the ground for a while I noticed that although the rippers easily cut the sod, the sod got clogged in the box blade. I raised the box blade and that helped, but I still had large clods of sod all over the field-not the result I was looking for. I continued to work the ground for a couple of hours, but did not like the results. I had never used a box blade before. Was this the wrong implement to use? I have a small 4 ft tiller that I could use, but my CK30 has a 5ft wheel width so I am not sure that would do the trick. I also have a small disk that Dad used with the old Farmall Cub, but again it is only about 4ft wide so I don't know if that would work. Can you guys give me some advice here?
