newbie looking for some guidance
   / newbie looking for some guidance
well I've been thinking and looking around a bit...the *only* thing it sounds like I really need something big for is the land clearing part..and a couple of people said even the L is borderline for that. I poked around on craigslist and it looks like I can get an older, working dozer or small excavator for well under 10k... so now I'm thinking this: buy b2920, do as much as I reasonably can with it, meanwhile watching for a decent older machine like this and use it for what the B can't do. then when I've got the clearing done I can just re-sell it...I"m thinking an old machine like that won't take much of a hit from depreciation over the year or two I might have it. any thoughts?
   / newbie looking for some guidance #32
If you can find a good, dependable one then it can be done. My son has a friend in construction who does this. He just got a good used dozer for about 10k and will get that back when he finishes a few jobs. The trick is in finding one that is:
1.good
2.used
3 reasonably priced
We usually barter for or rent things like that and it works for us.
So I got email quotes for a 2920 from the dealer over in WI (second one we went to) and Barlow's and they're pretty competetive -- Barlow was a little cheaper but ~700 delivery evens it out. I think we're going to head back thursday when we're both off work and give the B3200 and L3700 a second look and make our decision. *crosses fingers*
   / newbie looking for some guidance #34
Good luck.
   / newbie looking for some guidance #35
I think that any excavator, bulldozer or track loader that you can buy under 10K is an accident about to happen. Annew L Kubota with a warranty and with an FEL will do the job at around 21K, zero interest.
Make sure you have them mount a tooth bar.
   / newbie looking for some guidance #36
yea-- not sure a low $ used excavator/dozer is worth the $$....
Just know what you get yourself into.....
J
   / newbie looking for some guidance #37
Interesting, my L3400 feels more stable on the severe hills we have than my old B7500, on sidehilling. But then I have fluid in my tires now I did not have on the B. Also as to wife comment, my wife will drive the L, because it "feels more stable" and would not drive the B.. but part of this I think is psycological, as in you sit more down in an L and you sit more On a B. It is interesting how different people react to the same situation. Or maybe the situation is not the same, We have some really rotten hills:eek:
James K0UA
   / newbie looking for some guidance #38
I bought 42 acres in the hills (some could call mountains) to build a house on. I bought a Case 580k backhoe to start with. I got it at a local auction for a good price but I did buy it kind of blind since the 580e next to it I thought would sell cheaper. The land had large trees that needed removing, stumps and all. I thought about a trackhoe but because of how far I was moving things I also needed the loader and wheels. By itself it did good. It has great digging power and when digging side by side with one of Kubota's larger trackhoes it easily out digs it.
But because of the hills and the fact I needed to make a road I found I needed a small dozer as well. I found an older case 450 dozer at a dealer they just wanted to unload. The tracks were in good shape but a number of other things were very worn. Over the years I've had to replace some parts here and there but over all it's been good to me. I would never use it to make money though.
My plan was to buy a tractor with a backhoe on it so after the house was built I would still have the tractor. But for the amount of work I needed to do it would have really worked the tractor hard. I've thought about selling the 580k but it runs well and is paid for. I'm always needing it for one thing or another. Now I have the 4240 I'll see if it still holds true.
The 580k feels real tippy. I'm always feeling like the slightest lean it will roll. When I was using it daily to build the house and was more comfortable and that feeling went away but now I don't use it very often it's back and I'm very cautious even though I know by experience that I don't need to worry. But that cautiousness is a good thing. If you feel too comfortable you are more likely to make a mistake.
You have to remember the larger the tractor the higher you sit. The higher you sit the more you feel tippy. But you need to remember you are a couple of hundred pounds at most sitting on a 3000lb+ hunk of steel. it's center of gravity will not be altered much by your weight and is much lower than you are. Even if you sat on the top of the ROPS you are not going to change it's balance much. But sitting up there you will feel like even the smallest stone would be enough to flip you.
   / newbie looking for some guidance #39
Just my opinion but buy bigger than you think you will need; you'll use it and want more. And if one big thing goes wrong on your sub 10K trackhoe or dozer, it could cost you several more K.
   / newbie looking for some guidance #40
I think it's safe to say that if everyone on this board was given the chance to trade tractors, most would trade up, not down. I think when buying a tractor it is fairly easy to tell if a tractor is too big to work around your property. I don't think it is as easy to figure out if a tractor is to small to do the things you want to do. I think for most people that have never owned a tractor it would be very difficult to figure out what a specific tractor will do untill you use it for a while on you property. Once you use it and become comfertable with it, you will start to find it's limits. I owned my L3130 for 5 years. When I first purchased it I thought it was more than enough for what I wanted to do. After the first year or so I started wishing it had a little more horsepower, and it would lift a little more. Don't get me wrong, I was very happy with my 3130 for the 5 years I owned it. I learned to work within it's limits (barely). Now with my L45 I am very happy with it's power and size. It's not any bigger than my 3130 was, but has quite a bit more power. I think the L45 is it for me, we'll have to see in a couple of years.
The good thing about tractors is they hold their value pretty well. If you find you made a mistake and bought too small, or too big, you shouldn't take to big of a hit trading up or down.
Gary T.
2009 Ford F-550 4x4 Ext. Cab Brush Fire Truck (A59230)
2009 Ford F-550...
2019 CATERPILLAR  XQ35 GENERATOR (A58214)
2019 CATERPILLAR...
Year: 2014 Make: Volkswagen Model: Passat Vehicle Type: Passenger Car Mileage: 135,272 Plate: Body (A56859)
Year: 2014 Make...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
378721 (A54865)
378721 (A54865)
2015 Peterbilt 389 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 389...
