Newbie Hydraulic questions
   / Newbie Hydraulic questions #1
Tim M
I've got a Woods BH80X that sprung a large leak at the inlet port of the control valve. It only leaks when the pressure relief valve is activated.
The leak is at the connection of Item 6 (Adapter) to the valve body on page 47 of
showcontent
I cannot get an open end wrench on far enough to get a good grip on this adapter. Is there some kind of brake line type wrench I should be using here? Or do I need to take the steel line off the get a socket on it?
This diagram does not show any O rings. Are they implied? Is it a special type of o ring? It appears like the adapter was really hoarked on tight as I can see what looks like munged o ring pieces sticking out.
Thanks,
Tim
   / Newbie Hydraulic questions #2
That is probably an o-ring thread fitting. The o-ring is available from anywhere that makes hoses, or, it should be. Putting a socket on it may be the best way to take it off. Take the fitting off and bring it with you. Good luck.
   / Newbie Hydraulic questions #3
If you look at the description for item #6:
Adapter, 3/4 ORBM x 3/4 JICM
You will see that one side of the adapter is a ORBM (O-Ring Boss-Male) so there IS a O-Ring in there.
Remove the line, remove the fitting, replace O-ring and reassemble. There is no thread sealant required on either side of the adapter.
O ring was chewed up pretty bad. Replacing was a piece of cake. Just loosened the bracket underneath the platform holding the steel 90 deg inlet line and gently swiveled it out of the way so I could get a box end wrench on the adapter. Thanks guys!
2025 New/Unused Wolverine 48in Skid Steer Trencher (A51573)
2025 New/Unused...
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A52577)
2016 PETERBILT 579...
40FT Shipping Container (Modified for Parts Storage) (A51573)
40FT Shipping...
JOHN DEERE 7210R LOT NUMBER 270 (A53084)
JOHN DEERE 7210R...
UNUSED FUTURE 15" EXCAVATOR GRAPPLE (A51248)
UNUSED FUTURE 15"...
