Newbie Hydraulic questions
   / Newbie Hydraulic questions #1
Tim M
Bronze Member
I've got a Woods BH80X that sprung a large leak at the inlet port of the control valve. It only leaks when the pressure relief valve is activated.
The leak is at the connection of Item 6 (Adapter) to the valve body on page 47 of
showcontent
I cannot get an open end wrench on far enough to get a good grip on this adapter. Is there some kind of brake line type wrench I should be using here? Or do I need to take the steel line off the get a socket on it?
This diagram does not show any O rings. Are they implied? Is it a special type of o ring? It appears like the adapter was really hoarked on tight as I can see what looks like munged o ring pieces sticking out.
Thanks,
Tim
   / Newbie Hydraulic questions #2
That is probably an o-ring thread fitting. The o-ring is available from anywhere that makes hoses, or, it should be. Putting a socket on it may be the best way to take it off. Take the fitting off and bring it with you. Good luck.
   / Newbie Hydraulic questions #3
If you look at the description for item #6:
Adapter, 3/4 ORBM x 3/4 JICM
You will see that one side of the adapter is a ORBM (O-Ring Boss-Male) so there IS a O-Ring in there.
Remove the line, remove the fitting, replace O-ring and reassemble. There is no thread sealant required on either side of the adapter.
O ring was chewed up pretty bad. Replacing was a piece of cake. Just loosened the bracket underneath the platform holding the steel 90 deg inlet line and gently swiveled it out of the way so I could get a box end wrench on the adapter. Thanks guys!
2014 Yale 3 stage 8500lbs lift solid tire forklift (A53472)
2014 Yale 3 stage...
2016 CHEVROLET SIVERADO 4X4 PICKUP (A52577)
2016 CHEVROLET...
Selco V5-HD Vertical Hydraulic Baler (A51691)
Selco V5-HD...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
