Newbie has a question (Maybe stupid)
/ Newbie has a question (Maybe stupid) #1
okie350
Mounds Oklahoma
L3010 & BX2200
What is draft control? what is it for, and how do i know if i have it on my L3010?:eek:
/ Newbie has a question (Maybe stupid) #2
Draft control is primarily for plowing. It raises the implement if the rearward force is greater than what you select. It's designed so plows don't bog down in little rises and stall the tractor or run deeper than is useful. If you're not plowing, you don't really need it, though it can be used for some other tasks like using a box blade.
If you have it there will be a second lever next to the 3ph position control lever. It will usually be shorter but the same type of lever. I don't know offhand if an L3010 has draft control but I'm going to guess no, as it is not standard on the L30 and L40 series.
/ Newbie has a question (Maybe stupid) #3
Everything you never wanted to know about Draft Control:
Draft control, while not essential, makes life a little easier when plowing, sub-soiling, or using other ground engaging implements. For illustration purposes, let's assume we want to go plow up the back forty. We've mounted our plow to the three point hitch and adjusted things so that the plow will run straight and track properly behind the tractor. A note about plowing- if you have adjusted the plow properly, you should not have to use the stabilizer system to keep it running true behind the tractor. As you let the lift arms down, and begin to move forward though the field, the plow will start to enter the ground. As the plow continues down, traction and horsepower requirements increase. The natural tendency is for the plow to continue down until the tractor either loses traction, runs out of power, or the lift arms reach their lower limit. It is very unlikely that the latter will happen. We want to be able to plow at a reasonable depth without straining the engine or having excessive tire slippage. We also do not want to have to continually fiddle with the lift controls, raising and lowering the plow by small amounts, as ground conditions vary throughout the field. That's where draft control really helps. Draft control senses the amount of strain that the tractor is being subjected to from the plow. If the strain exceeds a predetermined level, the draft control will automatically raise the plow just enough to restore normal loading of the tractor. After you get past the hard spot in the field, the draft control automatically returns the plow to the pre-selected, ideal depth. There are two main types of draft sensing in wide use today. They are: lower link draft sensing, and top link draft sensing. Both achieve the same end result, and much discussion could be made over which is the best method. Generally you will find lower link sensing on larger, higher horsepower tractors. In the case of lower link sensing, the front of the lift arms are attached to a common bar that flexes with variable loading to impart movement to linkage that is ultimately connected to the control valve. There are also tractors on the market that incorporate an electronic lift control system. With these, the lower draft bar contains a strain sensor which sends a signal to an onboard computer. Movement of these electronic bars is almost undetectable to the eye. For tractors that utilize top link draft sensing, there are several methods in use to transmit draft load information to the control valve. For a large portion of North American style tractors, there is a rather large (usually internal) coil spring, which is compressed (by the top link) as draft load increases, and relaxed as the load diminishes. This compression/relaxation causes movement in the draft control linkage, thus changing the position on the control valve, raising and lowering the lift arms as needed. Other tractors (namely European style) have a massive leaf type spring between the top link and the lift cover. Still others use a torsion bar that is actually twisted as the top link moves toward and away from the tractor. Now, with all of this draft action going on, we've got to slow the lift system down some, or we'll end up with a rapid, out of control oscillation of the lift arms going up and down.
/ Newbie has a question (Maybe stupid) #4
That's very educative thanks Podunkadunk. I already know what draft control is but I have to say that it's well explained.
/ Newbie has a question (Maybe stupid) #5
I love this website!
Wow, that was informative!!!! I do not have draft control on the L3010, and guess i do no need it. Although, it may be nice with the box blade since i seem to do more damage than good, the wife cringes whenever she sees me heading for the driveway with it:rolleyes: some day I'll figure it out.
Great site
/ Newbie has a question (Maybe stupid) #7
I do enjoy this site tremendously!! Cudos to podunkadunk for his explanation. I just wish my 'Vette site could give me as much interesting and useful info about 'Vettes as I get here concerning my Kubotas.
/ Newbie has a question (Maybe stupid) #8
Guys, I wish I could take credit for that writeup on draft control, but truth is, I can't. I forgot exactly where I got it on the 'net, but a couple months ago, I ran across it and cut it out, pasted it into word format and saved it in my documents because it was the best darn draft control writeup I have ever read. Whomever wrote it did their homework, then simplified it for us (me) simpleton rednecks!
/ Newbie has a question (Maybe stupid) #9
Nonetheless, the information is there because of you, thanks again Pod.
New/Unused Quick Attach Backing/Mounting Plate (A65583)
New/Unused Quick...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2022 EZ-GO ELITE...
2019 Bobcat T650 (A64126)
2019 Bobcat T650...
KBH 25 TON TENDER (A61307)
KBH 25 TON TENDER...
Toro Groundmaster 580-D Lawn Mower (A66285)
Toro Groundmaster...
