Newbie from VA, TO-20 assembly question
   / Newbie from VA, TO-20 assembly question #1
rip5896
Crozier, VA
1948 Massey Furgeson TO-20
Just joined from Crozier, VA. 1948 TO-20. Replaced the seal and can't get the two parts mated. This looks like a great site, hopefully I'll become accomplished enough to contribute.
   / Newbie from VA, TO-20 assembly question #2
:welcome: to TBN fellow Virginian!
I can't help with your question, sorry.
If it were me I would post that question in the vintage tractor section. There are some VERY sharp folks frequenting that forum.
Be well,
David
Did not know there was a vintage section, thank you. Fortunately someone had answers for me.
   / Newbie from VA, TO-20 assembly question #5
Rip, welcome fellow Virginian! Have a Aunt/Uncle that live on Lee Rd in Crozier...nice little town.
   / Newbie from VA, TO-20 assembly question #6
Welcome!! I was born/raised on Shallow Well Road...I'm pretty sure you know where that is...still have a place in Georges Tavern that we are gonna build on soon...where did you find the TO-20? BobG in VA
PS: Have they sold the North Pole yet???
   / Newbie from VA, TO-20 assembly question #7
Hi rip5896.
First et me welcome you to the forum and i am sure other members will make you most welcome .
Your question ? I assume you replaced the rear seal on the engine in which case you had to split the tractor??.
If yes you removed the clutch and flywheel ??
you replaced the rope seal and refitted the flywheel and clutch ,??
If yes did you CENTRALIZE THE CLUTCH DRIVEN PLATE that is make sure the plate was Exactly in the centre if not you will have to split the tractor again and remove the clutch ,get either a bolt or a piece of round bar about six inches long that fits neatly into the flywheel bearing hole then using masking tape or insulating tape build up the diameter of the round bar so that it fits nice and tight into the splines on the clutch plate what you want to do is make sure the clutch plate is dead centre on the flywheel.
This is a cheap way to do it ,if you have access to a lathe make a tool out of steel.
When the plate and the clutch are assembled using two GUIDE bolts 7/16unc thread x4 inches long one each side of the bellhousing bring the two halves together line up the guide bolts and gently push the two halves togetherwhen you get them say two inches apart get a tape measure and measure the gap ALL THE WAY ROUND and adjust till it is equall when done gently push the two halves together ,it may be neccessary to put the tractor in gear and turn the engine buy hand just to line up the spline
Let me know how you go .
Happy Days
Hutch.
Thank you for the input. I've actually got it together again but I will save your information as I'm sure it will come in handy, it will be good to do it correctly next time.
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
RYOBI EASY START INVERTER GENERATOR (A51248)
RYOBI EASY START...
2025 SDLANCH IRGC40 UNUSED Electric Tricycle (A53117)
2025 SDLANCH...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
AUCTION STARTS HERE @ 9AM (A51246)
AUCTION STARTS...
CAT D3 LGP (A50123)
CAT D3 LGP (A50123)
