Newbie ct235
/ Newbie ct235 #1
Tnthemi
Oshkosh, WI
2011 Bobcat CT235
Hello all. New to the forum but will probably check it out more often when problems or questions arise. Recently purchased a used ct235 with 147hrs with allot of attachments. I then found a guy selling the mid mount mower. I got it for 500 bucks with all mounting parts. Im slowly cleaning it up and trying to figure out what I might need. I sharpened the blades but want to get some spares if needed. Also looking to get a replacement belt. My question am I stuck calling bobcat and ordering from them or does anyone make any aftermarket mower blades and belts? Any help appreciated. Mid mount mower is mm66.
/ Newbie ct235 #2
Welcome to TBN. It might help finding a local outlet for blades/belts if we knew you general location. Update your profile with your location.
/ Newbie ct235
Updated. But if it didn't work I'm in Oshkosh WI.
/ Newbie ct235 #4
Welcome to the forum. :welcome: You may already know there are on line part books for your tractor and mower. Your blade number is 7148755. 7148745 belt number.
I couldn't cross reference them to anything. I have had good luck in getting length, offset, hole diameter, blade thickness and being able to find blades. You can go to the Oregon sight and others to search. Oregon brand Lawn Mower Blades
You got a deal on the mower! :thumbsup:
/ Newbie ct235
Appreciate the info. It doesn't appear it's going to be much of a selection.
/ Newbie ct235 #6
:welcome: to TBN...enjoy.
/ Newbie ct235 #7
Bobcat did not make the mower or at least I do not think so. Find the mfg. and proceed that way.
/ Newbie ct235
I got it all hooked up and it seems like it should do the job. But my impression is that it turned my badass 4wd diesel tractor into a lawnmower. I'll obviously be taking this mid mount mower on and off. It takes your clearance down to life 3 inches or less. Looks like time wise 10-15 minutes on and off. Might have to remove drivers side step because my chest is too big to fit in between to hook up the pto underneath.
/ Newbie ct235 #9
In my humble opinion, a Bobcat tractor would not make a great mower.
Its the only thing I find to be a downside about mine, driving it across the grass in anything less than completly low moisture soil tends to make "tracks" due to how heavy they are built.
Otherwise mine is a freakin tanks!
/ Newbie ct235 #10
Do have to be a little careful but mine is a beast with a 6' finish mower. I can cover some ground. I have the ag tires.
Caterpillar 325/325L/325LN Excavator Service and Parts Manuals (A63117)
Caterpillar...
2020 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2020 FREIGHTLINER...
UNUSED WOLVERINE MAD-12-12D (A64281)
UNUSED WOLVERINE...
2005 Mack CL713 Truck (A60352)
2005 Mack CL713...
2025 Grapple Mini Excavator Attachment (A61572)
2025 Grapple Mini...
Caterpillar D4 Dozer Parts and Service Manuals (A63117)
Caterpillar D4...
