Newbie BX25 Delivered Last Friday 5/27
   / Newbie BX25 Delivered Last Friday 5/27 #1
toto55
BX25 2011
After 2 years of watching this site and research, finally bought a BX25
Absolutely love it. :thumbsup:
Already ordered BX expanded hooks
will order Extreme metal products thumb (they look better to use for pulling out brush by stream than Bro-tek)
First question :
Best way to scrape up about 3"-4" of sod for large areas ..Backhoe or get teeth for bucket? (general landscaping)
I'm finding a lot of practice is needed for even backhoe sod removal, the bucket is pretty easy to learn, but it doesn't scrape up sod.
Any tips? And Hello!
   / Newbie BX25 Delivered Last Friday 5/27 #2
Welcome to TBN. :)
   / Newbie BX25 Delivered Last Friday 5/27 #3
Try out the Ratchet Rake for scraping sod.I did quite a large area with mine and it does a great job.They have a video of it. Search ratchet rake and it should come up.
   / Newbie BX25 Delivered Last Friday 5/27 #4
welcome to tbn and congrats on bx ! If you only need to pull up sod 3-4 inch worth and have time- slow and steady will do it. If you do it before ground dries up, but not muddy, it should be a piece of cake with BX bucket in float.
I had to scrape about 2 inches or so of sod to clean out a ditch with my bucket. What I did was I put er in low, 4wd, and move an inch at a time with my hand on the FEL control. I would start out in float,curl and uncurl bucket as I go to keep things even. Once I started cutting, I would take it out of float and start lifting a bit without raising the bucket to take weight off ground since wet sod can be heavy and you don't want to cut too much. :thumbsup:
:laughing: the only way to understand what I said is go out and play- err i mean work with your tractor. :D
   / Newbie BX25 Delivered Last Friday 5/27 #5
Welcome to TBN!!! Congrats on your BX25! You'll love it! :thumbsup:
   / Newbie BX25 Delivered Last Friday 5/27 #6
Hello & WELCOME to TractorByNet.com! :)
I have moved your thread to the Attachments Forum. You'll get a better response there. ;)
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
JOHN DEERE 1700 (A53084)
JOHN DEERE 1700...
(2) COLUMN PROTECTORS (A51248)
(2) COLUMN...
