Newbie ? Adjusting 3 point sway
   / Newbie ? Adjusting 3 point sway #1
dougtrr2
SW Iowa
BX24
I have a BX24 and occasionally put a box blade on the three point. I have never adjusted the turnbuckles to take the sway out. I did that intentionally at first since I am working in areas with tree roots and wanted to give the box blade some leeway if it got hung up. Now I am wondering how tight the turnbuckles should be? How much sway (if any) should there be when a three point attachment is attached. Does it depend on the type of attachment? Thanks for your input.
Take Care,
Doug in SW IA
   / Newbie ? Adjusting 3 point sway #2
I adjust mine so I have about 2" of sway each side. This gives the turnbuckles a little "cushion" if I bump an immoveable object but not so much sway that I can't get a straight pattern from the implement. Too much sway on my RFM makes the yard look bad.
   / Newbie ? Adjusting 3 point sway #3
I leave very little sway .Too much and the attachment seems to snap from one side to the other when raised and making turns: adding too much force on the 3 point arms.
   / Newbie ? Adjusting 3 point sway #4
I'd lock 'em down so there was no sway if I could.
   / Newbie ? Adjusting 3 point sway #5
I leave a couple of inches on all my three point stuff.
   / Newbie ? Adjusting 3 point sway #6
The only 3-point implement I have is a carryall, so I get them as tight as I can.
   / Newbie ? Adjusting 3 point sway #7
On the 750 lb ballast barrel, Locked down tight, no sway. On the rotary cutter I leave some slack, an inch or two. That's what I do.
James K0UA
   / Newbie ? Adjusting 3 point sway #8
I personally hate any sways. I have mine tight so there feels like I got control which way my implement goes with a simple light turn of steering.
   / Newbie ? Adjusting 3 point sway #9
I want them at least tight enough not to rub on the inside wall of the downhill tire ...
Nick
   / Newbie ? Adjusting 3 point sway #10
I keep mine pretty tight...especially with implements with a PTO shaft, like my wood chipper and grass bagger.
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2017 Nissan Frontier Ext. Cab Pickup Truck (A55852)
2017 Nissan...
2009 Lexus RX 350 SUV (A53424)
2009 Lexus RX 350...
2006 APPA TL (A55787)
WHIRLPOOL DRYER (A54757)
WHIRLPOOL DRYER...
2020 LOAD KING JBTR-56 (A55745)
2020 LOAD KING...
