newbee PTO question
   / newbee PTO question #1
smalltown
Western Maine
2011, JD 2520
I had added this question to the end of another post, but I think it may have been buried.
I have been reading all the posts of front verses rear snowblowers. I read that the rear mounted is a lot less expensive, and some apparently like the idea of leaving the FEL installed.
Not being tractor wise I would like to ask what may surely be an obvious no brainer question, but for me I don't know.
When reading tractor specs for a unit that has both a rear and mid mount PTO, and it is stated for example that the PTO HP =18 does that mean that both the rear and the mid mount are 18HP. I know you don't have the option to install the same blower on either the front or rear.
But if you could I wanted to illiminate the rear PTO installed blower being able to throw snow futher than the same blower installed on the front using the mid-mount PTO.
   / newbee PTO question #2
In the spec's, a tractor has a rated engine HP and the PTO HP (PTO always being slightly less). As far as I know, the PTO HP is the same at both rear and mid connections. I've studied a lot of tractor brochures, and have never seen a distinction.
What are you trying to do, mount a blower on both ends of the tractor. I don't understand your question.
REV
Thanks REV. No I guess I should have said I wondered if there would be any difference in a given snowblower performance between powering the blower from the rear or mid mounted PTO.
I was just trying to avoid the issue of (if) I purchased a front blower that the dealer might say to me later "Oh you should have bought a rear blower they throw the snow further."
I know one thing what ever I eventually get, a soft sided cab is in my future, I cleared the snow out again today and I am so sick and tired of the wind changing and making me look like frosty the snowman.
   / newbee PTO question #4
There is no noticeable difference in HP between mid or rear PTO. While some people swear by rear mount, most of the time that's because their tractor may not have a front mount snow blower option (in JD that's pretty much anything over a 3xxx series). If you like craning your neck while you snowblow, that's an option. I would go front mount if at all possible though, as its much easier ergonomically. My $.02
   / newbee PTO question #5
ive looked into both the front and rear snowblower issues for the past 2 months, and it is confusing. If you mount a snowblower on the front, powered by a mid PTO, you will have to remove the loader and mount the blower to a sub-frame. If you mount to the rear, you can leave the loader installed to use in the areas where you cant blow.
Im going to order a LOADER mounted front snowblower for my tractor, but that will run off of hydraulic hoses attached to a rear 3 point mounted, rear PTO driven hydraulic pump. I need this because i want to be able to lift the blower up to reach the piles of snow that shed off of my 3 outbuildings. I get piles 5 feet high.
im also going to order a front blade for the slush. There is no one perfect solutiuon.
Thanks everybody.
One less thing I need to wonder about.
2018 MDB T5E MDB DISC MOWER (A51247)
2018 MDB T5E MDB...
Hyster H225E Forklift (A47477)
Hyster H225E...
UNUSED KIVEL 3500# PALLET FORKS (A54757)
UNUSED KIVEL 3500#...
2018 KUBOTA SVL95-2S SKID STEER (A52705)
2018 KUBOTA...
Hilti TE 2000-AVR Electric Jack Hammer (A52377)
Hilti TE 2000-AVR...
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
