Chipper Newbee needs Chipper Assistance
/ Newbee needs Chipper Assistance #1
SCRich
South Carolina
Kubota L3400 HST
I have 27.5 acres that just got logged, 3 acres clear cut 40% thinning of the rest. Heck I think the 40% was just the darn trails the CAT325 had to cut to get to the places, 3+ miles worth of trails by my GPS when I walked it. Needless to say loggers left a mess, going to cost me more in equipment to clean it than what I made and it would be too expensive to have done or rent the equipment.
So I was going to buy an ATV with a DR Chipper, the chipper is about $3200 plus the ATV that is about $10K. The Kubota I will eventually need is about $17K with a FEL grapple and I can buy a cheap or used ATV for later. Only thing I need is a storage container ($2000) for tractor storage since the home is not ready to move in till' August.
So back to the chipper, PTO chippers from DR are about $1200 but what else is out there ? The chipper will get heavy use the first few months maybe 6 months then just a bit of use afterwards every year. Trees are SC Pines, I am mostly concerned about branches and pine needles, the 6-7ft tree tops left behind I will cut and split for firewood. There are a few cedar trees but that is about it. The tractor will have no more than 25-29hp at the PTO so what can I expect to do with that power?
Any suggestions would be appreciated. I am new to owning more than an acre and I am spending about 6-7 hours a night on the internet learning everything from fireplaces, grading, seeding, etc etc. from 0-60 in no time to spare. Not to mention I am trying to keep a close eye on the construction of the home. We are only at the basement portion of it now but it will get hairy fast, the home is 5200sq ft modular and will arrive in about 3 weeks!
/ Newbee needs Chipper Assistance #2
Hey Rich;
Sounds like we have the same mess in common. I purchased 30 acres about 4 years ago that had been " terrorized " by loggers. They left a huge mess and cut trees on my existing property also. ( what jerks ) Needless to say I had a contractor with a 1150 case dozer blade the trails so they can be walked safely. I dragged them with my tractor and have them in fair shape. Now I would like to get a chipper and remove some of the dead trees along with the trash piles they left behind. I have research some brands and at a minimum I want to purchase a 6" pto unit. Renting is out because there will be work every year due to falling trees, branches ect. There is also a stream running through it so a couple bridges are in the plans. It is beautiful property very close to the city so it deserves a first class cleanup. A feature I would like to have is a hydraulic feed system. Working alone I feel this can be a huge back saver. The local dealer handles woods brand which is quite expensive. I'm trying to get a retail price on a BX 62 Walenstein and view one. From what I read they seem to be a well built unit ( four knifes and a 180# flywheel ) with the specs I have in mind.
/ Newbee needs Chipper Assistance #4
SCRich,
I have been working on a 30 acre tract that was logged. Sometimes I feel like I would be better off P*&*^%$ in a blowing fan. A friend hired someone with a deforester machine last fall to clear 4 acres on his property. He spent $2,000, but the machine shredded everything in it's path. If you want immediate results and can afford it, then I would hire someone.
I've been clearing my land wih the use of my 40hp tractor with a fel and it has been a slow process. In my opinion, the ATV and chipper will take forever. The ATV would be nice so you can ride on all the trails but it isn't designed to haul/move a lot of heavy timber. A tractor with a grappel/fel, and a chipper would be superior to the ATV & chipper.
/ Newbee needs Chipper Assistance #5
I say go with the tractor now and definately get a grapple. Also I just bought a canopy garage for mine to keep it out of the weather for a year or so while I build up capital for a little barn. It cost me 175 at costco. Its does the job and has held up very good this winter.
Todd_C said:
SCRich,
I looked into that, it's called Gyro-Trac and it's made just south of me near Charleston SC. Those babies are cool AND expensive!! So expensive that hardly anyone can afford one. I found 2 manufacturers of the unit and called them direct, got 1 lead each for owners of their product (mostly in the South End of the state) and neither wanted to head up to the NC/SC border where I live. Both gave me 1 other lead due to the distance involved and job. Both expect it to be a 1 day job to clean up and they will only travel for 3 day jobs. $2200 a day. Heck... that is 25-50% of the cost of a tractor, can't do that and sleep at night. I'd rather buy a tractor and do it the hard way.
Rich
/ Newbee needs Chipper Assistance #7
Hi Rich,
I bought a 9hp Dr Chipper two years ago when that had a 6-month "try it and if you don't like it return it for a full refund" deal. I returned it.
I have nothing against the Dr Chipper and I don't mean to bad-mouth them. It worked fine and would be nice for the occasional spring cleanup around a small yard. But I am clearing a driveway and homesite on 3.5 acres and it was much to small. I would have destroyed it in no time. With 27 acres like yours...forget about it.
If you're going to get a tractor, I would recommend a PTO-driven chipper. I have a Wallenstein BX42. See my response to "joes_427_vette" for more info and pictures.
http://www.tractorbynet.com/forums/attachments/97520-anyone-own-walenstein-bx62-chipper.html
Thanks for the input, I was afraid of that and glad that someone who actually has done it was able to back up my thoughts. I'll check into that other thread and ask around. With so many tractor places about here I have never seen a PTO chipper for sale, kind of surprised me.
/ Newbee needs Chipper Assistance #9
I have 27 acres and bought the DR PTO chipper last fall. I like it a lot. It works well and will handle some pretty big stuff. I considered the Jimna Chipper but it was a little big for my tractor.
I would definitely go with a PTO driven one especially for the later, occasional use.
Well the tractor is a done deal L3400, WRLong Root Grapple, Boxblade,FEL, and probably I'll get a rake too. Just dropped off a check for $650 for the container, 6 months for $650 delivered, don't matter if I have it for 5 or 7 he has a bunch and they do things "different" here in the south. Seems to be a nice guy can probably keep it longer for the same price. The tractor should be ready by Friday but not the grapple, that needs to be made and shipped.
Still looking at the DR chipper but the reviews are mixed, looked at some of the other posts and it looks like a good PTO chipper would be about $4K. Anyone have one in the $2K range other than the DR that they can recomend ? I hate to part with $4K for a chipper since it's 1/2 of the backhoe that I really want/need.
/ Newbee needs Chipper Assistance #11
I would look at the Wallenstein BX42, or BX62 for a tractor the size of yours.
The self feed versions are between 2k-3k, and judging by the imput I've had from users, and the video on their web site ..::: Wallenstein EMB MFG Inc. :::.. it looks like they work very well. They can be run on tractors from the size of the BX to whatever. Hydraulic feed can be added at a later date if you deem it necessary, but I don't think you would....
/ Newbee needs Chipper Assistance #12
Hi Rich, as mentioned in another thread i live near you and I've been through the same sort of thing but only with some smaller logging decks. I think you are right on track with the grapple. It will be very useful. However, i have mixed feelings about a chipper.
Pine debris decomposes very quickly. I'd move some, burn some, scatter some and it will be essentially gone in no time. If you will have other long term uses for the chipper then it may be a good idea. I took the low tech way out and it worked pretty well for me. Just a thought.
/ Newbee needs Chipper Assistance #13
Jinma 6 inch Wood Chipper and implements including backhoes,frontloaders, LE Version Tractor
The Jinma chipper costs less than the DR PTO Chipper. I had the DR PTO Chipper and returned it when I learned about the Jinma. Now I have the Jinma. Other than the little quirks associated with the Jinma, most of which have been addressed in this thread http://www.tractorbynet.com/forums/...rn-new-jimna-chipper.html?highlight=stop+burn
the Jinma is, by far, the best use of your $ (under $2K).
Go back and read the thread and I think you too will be convinced.
/ Newbee needs Chipper Assistance #14
If I had the horsepower I would have gone with the Jimna too. I cannot afford the $4k units and remain married.
If you don't have the horsepower for the Jimna then the DR works pretty well and is quite reliable.
Your L3400 can definitely handle the Jimna.
/ Newbee needs Chipper Assistance #16
I put an old 6x6 that I had laying around though the Jimna and it never even slowed down.
/ Newbee needs Chipper Assistance #17
rickmacheske said:
I have an L3400 and use the 6" Jinma chipper without an issue. It's huge and heavy but the L3400 handles it. I don't think I would want to take it over rough terrain. BTW...I didn't pay close to 2k for it. Try this link....Welcome to Emerybuilt.com!
Rickmacheske, I agree with you on the price. My reference to the $2K came from here DR® Power Equipment - Chipper Models
I bought my Jinma from Tommy at AFFORDABLE TRACTORS with an extra feed roller drive knuckle and an extra set of blades for less then my DR Chipper. I had the one without the discharge chute.
Don't get me wrong, the DR Chipper is a good piece of equipment, but a little small for the workload I was putting on it. Best of all DR was good to their word. I returned mine at the tail end of the 6 month period and they took it back, no questions asked and I received a full refund.
/ Newbee needs Chipper Assistance #18
Hi all- Thought I'd chime in; I bought the DR PTO Chipper/Shredder a year ago for cleaning up my 10 acres. I looked at larger commercial versions and used ones, but couldn't justify the prices I found. Think I paid about $3100 for the DR. Does it work? Absolutely. I've chipped oak, hickory, ash, cedar, pine and more, as well as taken care of all the garden material in the shredder. I cut down three huge old oak trees last fall and the chipper cleaned up the leftovers for me. It will handle 4" diameter, but I try to use it for 3" and less where possible, and cut up the larger stuff for the woodpile. But it's been a lifesaver for the winter ice damage debris and cutting back the thickets and woodland edges that keep growing and growing. Limitations? It's a small chute, so I use a cordless saw to trim angle branches, etc. The chipper blade is probably dull now and I have to lean on some of the brush as it goes in. Replacment blades are $49 bucks, but I could remove and sharpen it... still works well enough after a year though. I've probably put 50+ hours on the thing, which is a lot! Truth be told, the hardest part is gathering the branches- I have a lot of slopes so I tend to bring the branches to the machine and keep the chipped piles in fewer locations. I run it on a '90 JD 670 which is around 17 hp at the rear pto. The DR says it needs 18.5 hp, but it works fine for me with a little less. I love the fact that it's a pto chipper... I can drive it up and around the gravel drive and position it anywhere... and don't have another motor to maintain. The tractor sips fuel so that helps. No complaints so far, but a bigger chipper would definitely be a plus if you can afford it. I prefer the small size of this thing though, and can slide it around the concrete floor in the barn on its legs. All in all, I'm pretty satisfied with it. Here's a pic while working today. Good luck!
/ Newbee needs Chipper Assistance #19
Hi Beau!
Those little 670's are great little tractors, aren't they?
The only reason I traded up was to get more PTO HP for running a chipper (which I never bought...). There are times I wish I'd kept that 670...especially when it comes time to make a payment on the 790 (670 would have been paid off quite a while back).
Anyway, I see by your profile you have a 2320 as well. That tractor has 18 PTO HP and can operate as a stationary power unit. Have you ever ran your chipper on the 2320?
/ Newbee needs Chipper Assistance #20
Hi Roy- I knew someone would ask that! No, I haven't yet tried the chipper on the 2320... It's new enough that I've beel playing with, er working with the loader, box blade and mower. I've got a LP Quick Hitch on the 2320- so I do want to try it out as well. You're right about that 670 being a good machine... dealer wanted me to trade it, but it was paid off and I wanted the backup. The mower deck on that thing is like a tank, but it's pretty beat up. The manual shift on the 670 is nice at times, but when I climb on that 2320 it's just a pleasure to run around while working. That 670 has great low-end though- I still prefer it for the steeper areas with the wider rear tires and such, and as you know it will crawl in low. Funny though, I got used to the 2320 pretty dang quick...!
2005 GMC Canyon (A57148)
2005 GMC Canyon...
2025 Pabreak 80in. Skeleton Grapple Skid Steer Attachment (A61567)
2025 Pabreak 80in...
(4) Blackstone OTR 12-165 NHS Foam Filled Tires w/ Rims (A60463)
(4) Blackstone OTR...
2019 TAKEUCHI TL10V2 SKID STEER (A59823)
2019 TAKEUCHI...
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
2011 Ford Flex SUV (A61569)
2011 Ford Flex SUV...
