newbe help with used Kubota purchase
   / newbe help with used Kubota purchase #1
panthercoach
Alabama
I have tractor experience with an old '55 Ferguson, but I am a newbe to buying a tractor. I am looking today at a used Kubota L275 with 781 hours, ROPS, 2WD, turf tires, shuttle shift tranny for $4500. I would like any advice on some of the things to make sure to ask and things to be sure to check on the tractor to be sure it is as good as it seems. It is a local dealer for me with a good rep, but I want to be sure I don't miss anything easy to fix BEFORE I buy. Thanks for any help y'all can give me.
   / newbe help with used Kubota purchase #2
Donnie look at the new ones that meet your needs. While 781 hours aren't a lot it may have been someone elses problems. Right now, this time of year is the best promotional rates from Kubota you will see for years to come. Prime rate will be 8.5 percent by August. If you truly need a Tractor my advise is to buy new. Then you know what kind of treatment and service it's had.
   / newbe help with used Kubota purchase #3
Well I'll offer a few positives - and some stuff to check. An L275 with 781 hours still has a lot of service life left. This early Kubota series was well-made and they tend to last a very long time with very few problems. If it really is in good original condition, it could be worth the asking price (maybe a little high for 2wd).
Some things to check - Pull both dipsticks (engine and gearcase) - oil should be uniform dark color, no white or spoapy specs, gearcase oil shoul be clean and translucent. Look for any signs of oil leakage - it would be unusual since these tractors generally did not leak anywhere. An oil leak may indicate more serious damage. Look at the air filter element, it is a cleanable cartridge. The housing has a differential pressure indicator that goes red if clogged. If the element is damaged or missing it can be a deal breaker. Check that the pto can be disengaged. I think the L275 has a 2-stage clutch - partway down the travel clutch disengages - all the way down the pto clutch disengages. If the pedal linkage has been adjusted for travel clutch wear, it is possible the pto clutch will no longer release. This would mean a new travel clutch is needed.
Check that the hourmeter is working - these have a flexible shaft from the front of the engine which tends to break at the corner and stop working. If the hour meter is not functioning it's a sign of poor maintenance and/or higher hours than are showing.
Also, the paint on these tractors was not very weather-resistant. If it is shiny (and not repainted) that is a very good sign that it got reasonably good care. You can tell right away if a tractor has been repainted - lug nuts, alternator, starter, wiring, and most rubber hoses & clamps did NOT have paint on them originally. Have fun - hope this is useful. Dick B
2003 STERLING ACTERRA 11FT FLAT BED (A51222)
2003 STERLING...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
3014 (A50657)
3014 (A50657)
2016 John Deere 35G Mini Excavator (A49461)
2016 John Deere...
2013 Ford F-150 Ext. Cab Pickup Truck (A50323)
2013 Ford F-150...
Cat TH407C Telehandler (A51039)
Cat TH407C...
