NewB has Zero turn Engine replacement questions
   / NewB has Zero turn Engine replacement questions #1
pjntj
Troy Bilt
07 Simplicity Javelin, the 20HP Kohler Courage just went. Machine was great until then, I want to replace with a similiar HP B&S through the Northern Catalog. I'm shadetree mechanically inclined so I should be fine but I've never done one of these before.
1) What motor fits? Hits? I guess I'm measuring shaft diameter? and keway? I want to make sure I'm ordering the right one.
2) It should be: disco starter wire, fuel line, unbolt old and bolt in new correct? Any advice from guys that do motor swaps all the time have for me??
thanks to everyone in advance.
:cool:
Paul
Thanks Carl,
I ended up going with a similiar/nearly identical Kohler for a few reasons: 1) I wanted to be relatively certain not only did the shaft fit, but the linkages and whatever else were in the same place. 2) I really want to get another 3-4 years out of this mower before hopefully I will be in a postion to get a new one. If it lasts longer, great.
oh, progress: Old motor is out, came out pretty easy, clutch slipped off the shaft with a little prying, new one is still in the box waiting for a free 4 hour time slot for me to pop it in.
2017 Harley Davidson Electra Glide (A52377)
2017 Harley...
Ford Tractor (A50120)
2019 MACK PINNACLE P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
Utility Trailer (A52377)
Utility Trailer...
2011 Caterpillar 299C Two Speed Compact Track Loader Skid Steer (A52377)
2011 Caterpillar...
2005 PETERBILT 379 (A53843)
2005 PETERBILT 379...
