New ZD's for 2007 ???
   / New ZD's for 2007 ??? #1
JLoaf
White Co., ARKANSAS
Kubota L3830 DT & B2710
I heard that Kubota is re-designing the ZD's for 07.
Anyone know anything about that????
Ok, I'll whisper - I hear that Kubota is re-designing the ZD's for 07.
Is it true or not?
If so - what will be new?
And if so - maybe I can get a deal on a current model?
   / New ZD's for 2007 ??? #4
It would be difficult to create a better mowing machine than the current ZD's!
   / New ZD's for 2007 ??? #5
The Kubota factory rep told me the ZD mowers have some enhancements such as: more HP and pedal activated hydraulic mower deck lift.
Jon.
I've seen where a few manufacturers have come out with a 66" deck.
I think that would be a good addition to Kubota's line-up.
It would seem to be a good fit for the ZD25?
   / New ZD's for 2007 ??? #7
Also, the hydraulic problems on the ZD-28 that some were experiencing (stalling on hills, etc) are supposed to be fixed.
   / New ZD's for 2007 ??? #8
The ZD has had some transmission troubles that they are suppose to resolve. I was told that they use the same Trans. in both the ZG and ZD and it is just not heavy enough for the weight of the ZD causing transmission failures
   / New ZD's for 2007 ??? #9
Our ZD-21 only has 375 hours on it in during two years of severe heavy duty operation, but it has been flawless to date.
I have not heard about the transmission failures on the ZD series due to their heavy weight. Can you tell us more about the transmission design failures?
   / New ZD's for 2007 ??? #10
The ZG and ZD do not use the same tranny. Infact if you look at the sticker right on top of that you can clearly see that. Same design, yes - same pumps & motors - no.
Its never been my experience that these have lacked for power, and really its been a very good machine. You've gotta realize that Kubota has a very low tollerence for failure with their machines, and we have done work on a higher % of ZD's than we have on the other products. Not major stuff, for us its been mosty the o-rings around the axles.
2014 Volkswagen Passat TDI SE Sedan (A55853)
2014 Volkswagen...
2007 Hyundai Sonata GLS Sedan (A55853)
2007 Hyundai...
2017 BX2680 Sub Compact Utility Tractor (A55314)
2017 BX2680 Sub...
2014 John Deere 204K Wheel Loader (A53485)
2014 John Deere...
19088 (A55758)
19088 (A55758)
ZETOR 4340 TRACTOR (A57192)
ZETOR 4340 TRACTOR...
