New Z-Force 50
/ New Z-Force 50 #1
aratapuss
Finally made a decision, and bought the Z-Force. I have nowed my yard 4 times now, 2+ acres.
The 23 HP Kohler seems plenty powerful, and does not bog down in tall grass, or so it has seemed. The speed is quite nice, took awhile to be able to control the mower at top speed, but now it is second nature.
I am convinced this is the way to go, if one can afford the luxury of a ZTR and a tractor. Would not sell my CC 2180, account it compliments the Z-Force so well.
Sold my reel mower, a 7 gang unit, 8 1/2 feet cut, after using the ZTR twice. Love the cut of the gang mower, but the time I saved with the big cut, I more than lost in the trimming I had to do.
Went back to the dealer to buy an oil filter, and took another look at the different CC lines. After buying a unit, I can really spot the differences between the models now. No buyers remorse here, but I am fascinated at all the differences.
Read in another forum how the oil filters were a bother to change, changed mine, quite simple and easy, no mess, so I can discount that concern. I love the "no tools" deck removal on my 2180, and think the Z-Force deck removal is somewhat similiar, but have yet to actually drop the deck. Anyone here care to comment on their Z-Force deck removal?
Bought a second set of blades, about $72.00 total. Maybe a bit expensive, but they sure are heavy duty looking blades.
My wife thought I was nuts for buying it, however, after the second time she used it, she realized the benefit of the ZTR, and is now solidly in the positive. She mows quite well with it, and has a lot less time on it than I do.
Not worried about it not being a commercial unit, heck, I am sure I will probably want to buy a new unit in 9 or 10 years when I retire. I enjoy mowers and garden tractors, and can splurge somewhat, when I want. Almost bought a Simplicity ZTR, but the Z-Force just seemed to appeal to me more.
/ New Z-Force 50 #2
I recently bought a ZF50 as well.
I will be doing the intial oil change soo too.
I'd read about how messy it was, too. I haven't had time to look close, but isn't there an oil drain hose attached to the engine? I didn't notice anything in the CC manual or the Kohler manual about that. Maybe it's a model specific thing.
/ New Z-Force 50 #3
Just read your post and wanted to answer your question about dropping the deck on a ZF50. The best way I've found is if you have a way to hoist the front of the mower up it rolls right out real easy. I use a heavy duty block and tackle made for hanging large game animals with a short length of chain around the front axle next to both wheels. Release the belt tension, take the belt off the rear pulley, drop the deck all the way down. remove the outer guards, pull the pins on both sides, roll the deck forward enough to lift the front hangers up from their slots and then hoist it up. The deck will roll right out from under the frame. To make it even easier I replaced the cotter pins on the front hangers with hitch pins and take them completely off when I drop the deck. Hope this helps
/ New Z-Force 50 #4
/ New Z-Force 50 #5
I am looking to buy a new Cub Cadet ZTR mower. I am leaning toward the Cub Cadet RZT 50. It has a stamped deck. I have heard mixed feelings about the decks in comparison between the RZT and the Z-Force. Do you have any advice or opinions for me? Any real distinguishable differences in performance or durability between the decks? It would be much appreciated.
The RZT is about $1000 cheaper.
/ New Z-Force 50 #6
How much grass are you plannig on cutting with the machine? RZT is rated to cut 1.5 acres or less.
Z-Force has a better motor, frame, transmission, seat, front axle, larger tires & wheels...for ONLY 1K more...have to see it from that side of the fence also.
/ New Z-Force 50 #7
Do you have any idea how Cub Cadet stacks up to Toro/Wheelhorse?,their ZTR mowers, the ZX line? The ZX 480 in particular?
/ New Z-Force 50 #8
The first thing that pops out to me looking at the specs on the Toro ZX480 is that it uses a 20hp Briggs Intek engine, that motor is not near the motor a Kohler Command motor is (which is used on the Z-Force machines). Other than that they use the same transmissions, tires sizes are a toss up, seats look about the same. From looking at the picture I don't think the Toro has a pivoting front axle, the Cub does.
We sell the fire out of those Z-Force machines and hardly ever have complaints. Good luck.
/ New Z-Force 50
Thought I should give a 3 month update on my Z-Force.
Still very much enjoying the machine, the grass is fun to cut again, have had no mechanical problems of any sort. I did change the blades, but that was a waste of time, because the original blades were still in very good shape after 60 hours, but had the time and extra set, so it is done.....
Originally I had a bit of oil smoke when starting up cold, but that has gone away, no one at the dealer or otherwise thought it would be an issue, and they were correct.
All in all, a most satisfying purchase.
/ New Z-Force 50 #10
al copne, z force certian models I think the 48,and 50 inch decks are floating fabricated decks,10 gauge steel!I would go for a fabricated deck than a wimpy stamped deck! with a stamped deck if you hit something with the deck,which you will it could throw it out of wack or become warped,
/ New Z-Force 50 #11
I bought a Z force 60" which has even more grease fittings than the 50" I'm also extremely pleased with the unit and the price was right at TSC....$4300.00 out the door and in the pickup truck.
I cut my mowing time by 2/3rds and the 60" is way more economical on gas than my old 48" riding lawn tractor.
I've heard some negative things about MTD and Cub Cadet, but comparing the Z Force to my Kubota's, it's built as well as they are so I expect "0" problems.
I see that the oil filter for the Kawasaki is $15.00. That's pretty high as is the air filter. I also am curious as to where one gets the filters for the Hydro-Gear Pumps?
/ New Z-Force 50 #12
You think filters are bad, get a carb kit for a Kohler. Kohler has a weird sense of humor when it comes to profit margins.
6 O-rings, 4 screws, a spring and a low-speed needle.
$50.
I kid you not.
The greedy #$%%#$'s didn't even include a base or air-cleaner gasket.
-Larry
/ New Z-Force 50 #14
kubotafan said:
Looks like there are two different hydro's used on the Z-force. There is a 48" deck on one that is also heavier. Perhaps someone can give more info on the differences.
I believe there are actually 3 different drive units, however, all are made by Hydro-Gear.
The RZT 42" and 50" 0 turn residential riders use the HydroGear EZT pumps (2)
The ZForce 44 and 50 use the HydroGear IZT pumps (2)
The ZForce 60" uses the HydroGear ZT2800 dual pumps
I wasn't aware that the Cub came with a 48" deck in a zero turn
/ New Z-Force 50
I saw the Cub with the 48" deck after I bought my Z-Force 50. It had the nicer deck, but a smaller HP engine.
I believe it was about $5,000.00. Looked like a nice "stout" ZTR.
2002 Built Rite Trailer (A66285)
2002 Built Rite...
2006 JCB 506C HIGH LIFT TELEHANDLER (A62613)
2006 JCB 506C HIGH...
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
2020 Chevrolet 5500HD 4x4 Service Truck (A64556)
2020 Chevrolet...
New Quick Attach Power Spreader (A65579)
New Quick Attach...
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A62679)
2007 INTERNATIONAL...
