New X534
/ New X534 #1
Tlucch
2011 John Deere X534
Just picked up a new 2011 X534 last Thursday. I was surprised to see it came with this different seat. I know it's not open back but it appeared to be taller and more comfortable than the seat I've seen on X series machines with the open back so I didn't complain. Does anyone know if they are all going to start coming through with this change?
/ New X534 #2
Don't know about the seat change but the 534 is a good model. This will be the third season coming up that I have owned mine and I don't regret buying it! :)
/ New X534 #3
Looks good :cool:
I see the seat has a hole in it for water to drain.:thumbsup:
/ New X534
Thats good to hear JD, as you can imagine, much thought and debating went into this. I'm a little worried about the 4ws tilting the mower deck and cutting unevenly in turns. I've seen the complaint and I can visually see the deck move as I turn lock to lock. Have you had any issues like this or anything else?
/ New X534 #5
The 2011 X530/534/X540 all have that new seat. The X500/X530/X534 have a new engine and a smaller fuel tank.
/ New X534
I was told the "new engine" is a bit of a lie and they merely bumped the horsepower rating up one to avoid new emissions regulations but I can't confirm that. I had no idea the fuel tank was smaller...I'll check my documentation when I get home but I hope it's not too much smaller.
/ New X534 #9
For 2010 the engine was a 675cc 25 hp and a 5gal tank. For 2011 4.5 gal tank and a 726cc 26hp engine that is a diff. series engine than the 2010 engine.
/ New X534 #10
For 2011, you get 1 more horse power but less fuel for it:laughing:
/ New X534
Wow, that's a significantly bigger engine for 1 more hp, I wonder if it has much more torque. Being a different series of Kawasaki, any word whether it's better or worse in terms of quality? I hope all the air and oil filters I have on order will remain the same. 4.5 gallons is plenty, cubcadet GTs only have 2.5.
/ New X534 #12
It is hard to say if its better or worse but it is a diff. series. Its a Kawi so its good. I think the change was made because of emissions regs for 2011. Most things with a motor come under new emissions laws this year even boats with a I/O engine have to use a catalytic converter this year.
/ New X534 #13
The seat hole is for one of those moments when you get careless on a steep slope and nearly tip over.
Bobcat E80 (A64126)
Bobcat E80 (A64126)
2004 Winnebago Adventurer 38G 38ft. Class A Motorhome (A59231)
2004 Winnebago...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2000 CATERPILLAR 988F WHEEL LOADER (A62129)
2000 CATERPILLAR...
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
Brake Drums (A62613)
