Rear Finish Mower New Woods RD990X
   / New Woods RD990X #1
rbargeron
Elite Member
MA
L5450, L48, L3250, L345
I noticed the new Woods Finish Mower Brochure (April 2012) shows an RD990X model that apparently replaces the RM990. Anybody seen one up close?
From the pics it seems slightly less beefy - castor arms and lower links don't look as rugged. They are recommending a 45-75 hp tractor. But backing up close to an obstacle with that much tractor risks folding the rear castors like a cheap suit. Compare pics of RD990X and former RM990.
   / New Woods RD990X #2
From the pics it seems slightly less beefy - castor arms and lower links don't look as rugged. They are recommending a 45-75 hp tractor. But backing up close to a tree with that much tractor risks folding the rear castors like a cheap suit. Compare pics of RD990X and former RM990.
According to the specs it is actually heavier, 1300+ pounds.
I wouldn't care for the spacer washers for height adjustment. Probably loose them. http://www.woodsequipment.com/uploadedFiles/Products/Manuals/MAN0845.pdf
   / New Woods RD990X #3
Cant imagine trying to use a Finish mower with a 90" cut flat deck unless your intended use was to mow golf course fairways or sod farms.
my property has enough unevenness that even my 72" MMM will cut funky if im not carefull on transition areas.
   / New Woods RD990X
According to the specs it is actually heavier, 1300+ pounds....... http://www.woodsequipment.com/uploadedFiles/Products/Manuals/MAN0845.pdf
It sure looks lighter - maybe the 1300+ lb includes the chain plates (about 250 lb) ? Those height adjuster washers are retained by a regular snap hitch pin at the top. I used a Bush Hog 6' with those and the pin got knocked loose by vegetation, allowing the whole castor to fall off.
Woods has always done a good job on their 90" heavy duty finish mower - I should probably not criticize the new model based only on pictures. It's just that whenever a product is really rugged, some fresh little MBA genius thinks they can take the money out of it and they just screw it up. Oops, showing my age here...
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
2006 Toyota Prius (A56859)
2006 Toyota Prius...
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A58214)
2018 PJ TRAILER...
2010 International 7600 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A55973)
2010 International...
Caterpillar 259D (A57148)
Caterpillar 259D...
