New Well Drilled Yesterday
   / New Well Drilled Yesterday #1
wjmst
Strongstown, PA
kubota bx2200
We had a well drilled yesterday and I wanted to give everyone the results. We currently use spring water, which is good until late August, then it dries up. The other problem is in the winter when it freezes. So we opted for a well to hopefully solve both problems. We are located in South-West-Central Rural Pennsylvania.
Yesterday they came out and drilled it. You can check out the photos at:
Flickr: Photos from wjmst
The results and costs are:
120 ft deep $6.75 a foot = $810
20 ft of Casing $5.50 a foot = $110
1 Well Cap = $25
1 Ben Seal = $18
Total cost was $963
The process took two guys about 3.5 hours. They found water around 40ft, which was 3 gallons per minute and then more water at 90 feet, which was about 5 gallons per minute. That should give us about 8 gallons per minute, which should be enough water for us.
After we dig the trench to the house, they will come back and install the pump and connect everything up. They estimate the cost for this will be about $1200 to $1500.
Does anybody know what the (approx) storage capacity of the well will be? If I remember right the volume involves multiplying by pi or something. Maybe there is an online calculator somewhere.
Wes
   / New Well Drilled Yesterday #2
The formula I think you want is area of circle pi times r square.
It looks like your well is 6 inch dia.
If that is correct then 3.1416 x 9 = 28.2744 sq.inches.
One cu.ft = 7.48 gal. = 1728 cu.inches
One foot of 6 inch pipe 12 x 28.2744 = 339.29 cu.inches.
Looks like a little over 5 gal per foot of 6 inch pipe.
Now how deep is the water going to be when it levels off?
Question: Well 120 deep only 20 feet of casing????
I guess if it is in solid rock then no casing needed?????
   / New Well Drilled Yesterday #3
vol of a cylinder
pi*D^2/4 * depth of water
makes shure you keep your units the same.
so for a 6" well (.5 ft)
3.14*(.5*.5)/4 =.1963 *depth of water in ft.
90' well 10-15' below surface for top water level... pump sits 10' off bottom?
~60' of water? = ~12 cubic feet = 90 gal..... (1cuft = 7.48 gal)
but if it can sustain 8gal/min then the amount of water you have in "reserve" doesnt really matter.
   / New Well Drilled Yesterday #4
gotrocks,
not to be rude but something went wrong with your math. 5 gallons per foot is way too much, it should be closer to 1-1.5 gallons per foot.
Alright I just found the info I think I needed.
1 US gallon equals 231 cubic inches
volume of a 6" pipe is 339 cubic inches
339 (volume of pipe/well hole diameter in cubic inches) divided by 231 (the volume of water in a gallon using cubic inches), equals 1.46 gallons per foot.
Now for the next math wizard to come alongand correct me.
steve
   / New Well Drilled Yesterday #5
I think the answer is approximately 1.5 gallons per foot in a 6" ID cylinder.
Is there a prize for the first correct answer?
edit: Dang! Steve beat me to it!
   / New Well Drilled Yesterday #6
Who cares about the volume (1.46 gals/ft is right) but with 8 gals/min flow that is really good news. That should serve all your needs. Your pump will most likely pump less than that anyway?
Another thing, I'd be thrilled to death if that was all it cost to drill the well. Those rates are half of what they are out here in CA.
Great photos too...
I am very happy for you.
   / New Well Drilled Yesterday #7
I went down 575 ft. and it cost me 20k, another 5k for the Aquavar set up and pump.
You should be doing the jig for only spending what you spent.
   / New Well Drilled Yesterday #8
I agree - that is pretty cheap compared to what I've seen. Although I've never seen it broken down like that - a complete set-up seems to run about $3,000 where I am for similar depths. I think the big savings is that he only needs 20 ft of casing.
   / New Well Drilled Yesterday #9
1 Well Cap = $25
1 Ben Seal = $18
Total cost was $963
Wes
Table 1. Storage capacity of well casing or pipe.
Well diameter (inches) Storage per foot of water depth (gallons per foot)
2 0.16
3 0.37
4 0.65
5 1.02
6 1.47
8 2.61
10 4.08
12 5.87
from-http://www.ext.colostate.edu/PUBS/NATRES/06703.html
   / New Well Drilled Yesterday #10
Steve, Thanks for correcting my math paper. Not rude at all.
If I'd been thinking it would be obvious a 12 inch pipe 6 inch dia. would not hold what a 5 gal bucket would hold.
I'm still wondering about 20 feet of casing in a 120 well....
My well driller said he hit rock at 185 feet, 30 gal/min, my corn loves the cold fresh water during drought. He installed pvc casing all the way down, some solid ,some perforated to let water in.
True story, lady came into the lumber yard office and said
" I want 2 pieces by 4 "
1999 FORD F550 BOX TRUCK (A54313)
1999 FORD F550 BOX...
2013 Ford F-550 4x4 Ext. Cab Service Truck (A53422)
2013 Ford F-550...
2025 SDLL30 Mini Stand-On Track Loader Skid Steer (A53421)
2025 SDLL30 Mini...
2012 TRAVIS 39FT DUMP TRAILER (A54607)
2012 TRAVIS 39FT...
Filing Cabinets (A52378)
Filing Cabinets...
Massey Ferguson 9250 (A55301)
Massey Ferguson...
