New VS Old. Need help
/ New VS Old. Need help #1
Bill Stocklin
Round Rock, Tx
Several
I've tried the search function and can't really seem to get the right search to help me.
I need a tractor for several things.
1. Maintaining a road that has a LOT of truck traffic. I'd like to be able to pull a Johnson Hygrade or something similar. I have a road maintainer attachment (works good, but hard to keep the ditches clean- hence the grader) and a box blade that I use.
2. run pto jobs. Mostly a firewood processor. Doesn't need big power for this. Hence one of the pluses of the newer tractor- the economy mode of the JD pto's. edit- thinking about it, I probably would keep using my little tractor I have now for this.
3. General loader work. I have cattle and need to be able to unload and store them under the hay shed (stacked bales) so I don't wanna have something that feels like it's going to fall over when I get something heavy up high.
4. we also keep some gravel and materials stock piled around our yard and need to load it up on trucks from time to time so a decent sized bucket would be nice. It's not like production work or it will do it all the time, but it would be nice. You know how it goes, once you have stuff with loaders, you wonder how you ever lived before
5. Shredding. I've got about 40 acres that I mow off and on, and occasionally do favors for neighbors mowing (I like doing it- it's relaxing for me). I also do basic field maintenance, aeration, spraying, stuff like that.
6. I would use it to move trailers and stuff around my yard quite a bit.
So here is my question- I really like the older tractors, like 4450 in MFWD w loader. I like how they look, I like how they sound, how they are simple and how a monkey can fix 90% of the problems. Parts are easily available and relatively cheap. I owned one in the past (2wd ps) and really liked it.
I do, however, understand that technology brings better things. Big power in smaller packages, efficiency, longevity, diagnostics, comfort.
I have chronic back problems and one of the reasons I need a different (read bigger and smoother) tractor. I also need something bigger to pull a larger grader and deal with double stacked bales.
I was looking at 6140 ish sized. they lift high, powerful, nice, buddy seat (that's right- I said it- I'm a softy). but I need advice
What do you all think would be better? Why? Which would do better at pulling a tough to pull grader (I cannot express enough how difficult this road is- it's private and the ditches fill with silt when it rains hard- farmer REFUSES to let me put a berm in his field and he TRASHES my ditches and road if I don't keep it up regular. I now clean it with a skid steer or back hoe).
Which would be more comfortable?
Just a better fit.
Sorry for long first real post.
oh, and I'm big. I'm 6'6" and like 325. Need something easy to get into and comfy when you are running it.
/ New VS Old. Need help #3
The old JD 4450 great tractor i think about 140hp. if you find a great deal you would be looking at about $30,000 and 3 to 10 thousand hours on it. Looking at your list it looks like you could get by with about 50 to 100 hp. My JD 5085e was about 50k new with lots extras. My brother just purchased a Kubota M7060 in the mid $40's plus they have some great financing on new tractors right now. The JD is heaver and may handle your bails with more ease. Both the Deere and Kubota have e 540 pto. I think the shorter Wheel base of the Kubota would be great for moving your trailers around. Good luck on your search.
Ksluy, thanks for the reply. I would be fine with a tractor that size if it weren't for keeping the road up. The tractor I have now won't begin to pull my buddies Johnson Hygrade 1200 grader (I was going to get something like that, but 10') and it's 61 hp. I also need something that has AT LEAST 3 hydraulic outlets to run a grader like that, which pretty much mandates larger tractors. The 61 hp also wont run my 18' batwing in high grass or reach the trucks that I have (10' to the top of the sides- it wont even get close). I noticed on the JD website that the 6115 and up will lift to 12'8". Koyker website says that their loader for 4450ish tractor lifts to 14', so other brands should be similar. As far as moving the trailers around, I have plenty of room- my yard is pretty spread out.
I also was looking for advice on the ride quality of the older 4450 (and/or things I should be looking for or buy for it) vs the 6130/6140 style tractors.
/ New VS Old. Need help #5
for a 6140jd youll be looking at $85,000 to $90,000 with a loader new.as said the 4450s are $25,000 and more.
/ New VS Old. Need help #6
I would go with the 4450 ish. More tractor for less money.
/ New VS Old. Need help #7
Be careful comparing newer to older tractors. Everyone advertises engine hp now which is pretty much a useless number but it's a selling point. If your main use is pulling a high draft implement, I'dlook very closely at the base weight of the tractors. Kubota's are a nice machine but they are to light. Take the additional weight purchase into consideration.
With the 6140, I'm assuming your talking a D series. Thus is a basic tractor. Aka mechanical seat, two outlets and with that a cheaper price. Make sure you check on adoing remotes anD an air suspension seat for your back. Also, JD usually has two loaders that will fit a tractor. On mine I had the option of a 553 or 563 model and I went with the bigger one. I cant get enough weight on the tires alone without my concrete counter weight.
/ New VS Old. Need help #8
Maybe 2 tractors? A big 2wd (or 4 if you want to spend the cash) wouldn't need a loader, basically just to pull the grader and the bat wing. Something like a JD 4320 could do it, right? Then a 60 HP 4wd loader tractor for the rest of the list. Just a thought.
The only problem is, I want it to be able to load over a 10' high bed side. I currently use a back hoe to load the trucks, problem is, the backhoe is usually out on jobs, so we can't use material we have at the yard, which would save a ton of money and travel time, since the trucks are already here in the morning.
I know what the tractors cost. What I'm asking is, what do you guys think is a better tractor and which is more comfortable? I figured the 4450 (I'm just picking that number as a reference- I'm not stuck on that tractor) would be much better at the pulling at 12,745 base weight vs 8700 for the 6140 (I'm not sold on that model either- just using it as a reference of the newer style tractors that will reach as high as I need them to). That's almost 50% more base weight- with more power- obviously going to be a better high draft machine.
/ New VS Old. Need help #10
Good point. Forgot about the high loading.
One idea for some better answers, put something like "looking for full-size utility tractor, maybe JD 4450" in the title of a post.
Not many users on this forum have tractors in this size category. Certainly some, but not many. You need to find a way to get the few who have these big rigs to see your post. The rest of us won't be of much help determining which is more comfortable.
Yea, the heading was probably dumb of me. I'll let this one run for a while then maybe try again in another section on here with some clarifications. Thanks. Good suggestion.
Would there be a popular forum for larger tractor information?? I guess that's a long shot. LOL.
/ New VS Old. Need help #12
The guys on "yesterday's tractors" might be of service. They are pretty helpful. Otherwise, see if you can find someone in your area with one to test drive. For sale or not. That's the only real way to see if you like a machine, as I'm sure you know. Good luck in your pursuit.
/ New VS Old. Need help #13
My cousin went through this decision this past year. He maintains his ranch roads and stock dams with a pull-type scraper that looks like about 5 yard capacity. Been a 4430 2wd with weighted singles. Also feeds big rounds and gathers rounds with that tractor. 2wd was always a headache. Most guys in that area have moved up the 7000 series machines - pretty hilly.
He couldn't see spendin' that kind money! Finally settled on a 4255 4wd with loader, cab, new rubber, etc for $52K. Brand new 740 loader with grapple bucket for $13K.
IMO - the 50/55 series are way more tractor than the 6000 D and M series. Gotta look at the 6000R's or the small frame 7000's to really be in the same ballpark as the 50-55's.
Good luck.
AKfish
/ New VS Old. Need help #14
Good luck.
AKfish
sorry if i seem rude but the 6m and 6r are roughly the same machine, the m is a standard and r is premium (just like 6030 standard vs 6030 premium) I drive both as its my job and apart from the plastic work theres no major difference.
all new 7r tractors are 1 frame size only
/ New VS Old. Need help #15
If you did not know there are many major differences on the 6M Vs. 6R sector not just the plastic work. If you did not know AKFish was speaking about the previous series of the small 7000 Series.
What you can get on 6R and not on the 6M. There's more that's just what comes to my mind.
31MPH / 50K Transmission
Larger Cab
Larger Hydraulic Pump
Electronic SCVs / More SCVs
Front Suspension + Cab Suspension
More Lighting
Better Tire Options
Power Boost
/ New VS Old. Need help #16
Larger Cab
More Lighting
Better Tire Options
Power Boost
Thanks Edward, for filling in the blanks. You got alot better idea of the 'details' than I'll likely ever have for those bigger iron machines!
I know a guy shouldn't "generalize" and just broadly categorize something when you're trying to explain your thoughts - but it's easier, quicker to the point - and I'm lazy that way!
Nonetheless, the OP was referencing the 6000D more than other models and I should have focused my comparisons there. And specifically, the D models are limited by the transmission and hydraulic options available. The M's are a much better step up in that regard.
My cousin bought a JD4255 MFWD with full power shift transmission in Ohio from a big horse barn operation for $52K. Like new condition, 10K hours with a reman engine. I don't believe you can 1.) get a power shift transmission in a D or a full power shift in a M and 2.) get either for one $52K.
AKfish
/ New VS Old. Need help #17
AKfish
The problem is that the OP is tall and large, I would suspect a 6R would suit him the best due to the spacious cab. It is extra money but its money well spent if you want to be comfortable.
I picked up a 7810 earlier this year with 4200 hours on the clock for 65k. Has a P/S transmission as well, it is starting to grow on me.
Thanks for all the info. I never think I referenced a 6R or D or anything. Honestly, I don't know which one is which. I just said 6 series because it appeared to be the smallest tractor that would reach high w loader.
Ride quality, new vs old?
Old vs new? Better/ reliable?
I have noticed in my searches that most the 50 series only have 2 outlets and you use them to run loader. In that respect, seems like the newer tractors are more conducive to loader work w LH reverse and integrated loader joystick and still have 2-3 outlets to do stuff w.
Anyone know how many sets of remotes you can conveniently have on 6 series? It would be nice to have 4,1 for tilt cylinder and 3 to do stuff 3.
/ New VS Old. Need help #19
D Series - Economy Series
M Series - A mix between both.
R Series - Premium Series
On a 6M/R you can easily have 3 sets for the loader Up - Down , Dump - Curl, and for a grapple opening and closing.
6R on the rear I believe minimum is 2 sets and maximum is 4 sets.
If it was a tractor strictly that has to do with loader work I would pick up a 6M/R series just because its operator friendly. Having a powershift to do loader work is never a fun task.
/ New VS Old. Need help #20
I believe you can get 4 remotes on a 6M. Have you thought about a 6150M with the H360 Loader? Whatever you get, get a grapple.
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
2012 MAGNUM TRAILER WATER TRAILER (A67714)
2012 MAGNUM...
MANIFOLD (A68842)
MANIFOLD (A68842)
16 Pipe Squeezer (A67714)
16 Pipe Squeezer...
100 GALLON FUEL TANK/ FUEL NOZZLE (A68842)
100 GALLON FUEL...
DIGGIT 72MM MULCHING HEAD (A65056)
DIGGIT 72MM...
