New/used XJ2025 owner, serial number location
   / New/used XJ2025 owner, serial number location #1
dwalk19
Addison, ny
2018 LS XG3140H TLB
Anybody know where or if there even is a serial number badge anywhere on the xj2025, I found the serial number for the backhoe and can't locate for tractor or loader, I know the kubota I owned briefly before this all had there own serial numbers, thanks
   / New/used XJ2025 owner, serial number location #2
Yes they each have the tag. I think the tractor had two if I'm not mistaken. The manual shows the location of the chassis tag just ahead of the left front axle on the frame. I thought that there was another on the rear behind the seat too.
Yes I found them when I actually took the time to look, any recommended attachments, and the backhoe is a bit of a trick to get lined up correctly to take on and off but as always I guess the more you do it easier it gets
2010 Ford Fusion Sedan (A56859)
2010 Ford Fusion...
2016 Case CX55B Midi Excavator (A55973)
2016 Case CX55B...
1998 6.5x16 Anderson Utility Trailer (A56859)
1998 6.5x16...
20 UTILITY TRAILER (A58214)
20 UTILITY TRAILER...
2015 AMERITRAIL MANIFOLD TRAILER (A55745)
2015 AMERITRAIL...
Sand Blaster (A55973)
