New used ms441 magnum
   / New used ms441 magnum #1
andrehoude123
Just bought an ms441 from a friend for a good price it only came with a 18" inch bar what could it run to? 28 inch or 36? I want to cut some big poplar
And a full skip chain? Or semi-skip?
Thanks
   / New used ms441 magnum #2
Nice saw, it'll run a 36" but that's a lot of bar to carry around. I'd put a 28" on it. If you're cutting big poplar a full skip full chisel will be the cat's meow. Get a few chains for different purposes to see what you like. I usually run a semi-skip semi-chisel on my 361 with a 25" bar. I cut mixed hard/soft wood. Semi skip is a lot faster to sharpen than full comp and less aggressive than full-skip.
   / New used ms441 magnum #4
Had older 041's and now a 441 . 28" is good , 25" also works . Depending on your experience , Be wary of full skip . I have another thread here about full skip , But I have been running saws both personally and professionally for 38+ years . Most often they are used in softwoods , at least professionally around here , I bought mine as I needed a back-up chain and that's all they had . I am running mine in a Truck load of Hardwood , Oak and Madrone , But again , Been around saws for awhile . I have had no issue's , kick back or other .
Fred H.
   / New used ms441 magnum #5
Oh, almost forgot. USE CHAPS. They cost $80, but what're your legs (or your life) worth?
   / New used ms441 magnum #6
I run a 16" on the 026, 20" on the ms361, 25" on the ms460, 36" on the 2100cd. Some people want a bar that reaches all the way through the trunk of the tree. I would rather have a bar that reaches past the center of the tree and not have to carry a long bar all day.
   / New used ms441 magnum #7
I'd only go full skip if cutting evergreen softwoods and you have problems clearing chips from the cut.
For everyday use I like a 20" bar on my 461. I have a 28" bar for special occasions, and it's one of Stihl's ES Light bars, so it does not weigh any more than the 20" bar and does not disrupt balance of the saw. You do need to worry about weight/balance if you go with long bars of standard construction, as the saw can become unwieldy to handle.
For day to day use, pick a bar that's as short as possible, since it will be the most versatile, fatigue you the least, and the saw will be able to power it more easily (all else equal). Don't go with a long bar every day unless you are cutting big wood every day.
Ya for everyday use I use the 18 inch bar but we have so really big poplar that need to be cut and ya my chaps are always on
   / New used ms441 magnum #9
Isn't a 20" bar on a 046 a hoot s219! Sort of like putting a V8 motor in a small car. Like others have said not having too long of a bar to drag around helps a lot as far as fatigue and safety.
   / New used ms441 magnum #10
Yeah, it spoils me! Makes it tough to go back to my smaller saws.
My-D Hand 10 x 40 Auger (A50515)
My-D Hand 10 x 40...
John Deere 7130 Loader Tractor (A50514)
John Deere 7130...
2007 Freightliner M2 106 Ambulance (A51692)
2007 Freightliner...
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
2020 Ford F-250 Ext. Cab Pickup Truck (A50323)
2020 Ford F-250...
2019 TOYOTA 8FGCU25 PROPANE FORKLIFT (A52141)
2019 TOYOTA...
