New turbo tractors idle so high why?
   / New turbo tractors idle so high why? #1
Farmert22
Wv
Nh55
My new work master idles a little over 1k rpms. Do you see any problem with lowering the idle down to about 700 or so? I wouldn't think it would do anything negative to turbo do you guys!
   / New turbo tractors idle so high why? #2
I tried adjusting the idle down from 1250 on my V417, with a 75hp turboed Kubota, but it was really rough. :thumbdown:
   / New turbo tractors idle so high why? #3
It probably won't hurt anything to lower it if you can. However to let it idle for any period of time at low speed is not good. My JD operator manual says to avoid idling for more than 3-4 minutes below 1200 rpm, even though low idle is set around 850 rpm (5045D, turbo).
2011 20ft. Anderson Lowbed Trailer (A56859)
2011 20ft...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2019 Ford Explorer AWD SUV (A56859)
2019 Ford Explorer...
BUSH & BOG 16 BLADE DISC HARROW (A52708)
BUSH & BOG 16...
New/Unused 10ft X 20ft Single Garage Metal Shed (A57454)
New/Unused 10ft X...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
