New Tractor
/ New Tractor #1
Engine Mike
Rochester hills michigan
Kubota B2320
I just bought my first tractor, a Kubota 2320 with a bucket. Can anyone suggest a tool to level a piece of ground I have cleared to plant grass seed? Sme say a landscape rake and if you agree which one is the best value an what size do I need?
Thanks
Engine Mike
/ New Tractor #2
Gday Mike
My advice would be a Box Blade with rippers probably a 4' one would do the trick they are an awesome bit of kit will be the next thing I get for my lil bota
Dave
/ New Tractor #3
If you continue to post on T-B-N you will get more replies if you display the horsepower and weight of your tractor; 23-hp / 1480 pounds. Then everyone with tractors in your category can reply. Model numbers are not very informative.
If you just need to groom loose dirt, without hillocks, grass and vegetation, a 60" Landscape Rake will work. A Landscape Rake moves dirt and SMOOTHS but its flexible tines do not have the ability to CUT. As Landscape Rakes are usually pulled on an angle, infrequently "straight", you want a rake 12" wider than your tire width, so rake will cover enough work area when angled. ~6" wider per side.
If you need to level dirt, i.e.: cut mounds to fill in low areas, you need a 48" Box Blade, which has a CUTTING edge. As you may or may not know, the hydraulic system lifts the tractor's 3-Pt. Hitch, but gravity returns every ground engaging implement to work, there is no hydraulic down pressure, therefore: A box blade needs to be as heavy as your tractor can manage in order to cut. If you buy too light a box blade it will bounce along the surface, not cut.
Look for a 48" box blade 350-400 pounds. Box Blades are near indestructible....one of the implements OK to buy used, if you can find one heavy enough. So often only light blades are available used, sold by owners disgusted that they do not cut because they are too light.
Generally speaking a Box Blade will be twice the weight of equivalent Landscape Rake and proportionally more expensive.
You must have four wheel drive to successfully pull a dirt-filled Box Blade.
Here is a LINK to 436 threads on T-B-N having the word LANDSCAPE in the title:
http://www.tractorbynet.com/forums/search.php?searchid=385716
If your grooming needs are minimal you might consider a CHAIN/DRAG HARROW as an alternative:
http://www.tractorsupply.com/en/store/loyal-drag-harrow-4-ft-x-4-ft
2020 International LT625 Sleeper 48" (A62613)
2020 International...
APPROX (14) 20'-35' HEAVY DUTY INSULATED PANELS (A62131)
APPROX (14)...
2017 GMC 3500 Enclosed Service Body Truck (A62613)
2017 GMC 3500...
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A62131)
UNUSED WOLVERINE...
DRILL CABINET SKID (A60736)
DRILL CABINET SKID...
(APPROX. 100) UNUSED SDLANCH 6' CORRUGATED STEEL (A62131)
(APPROX. 100)...
