New tractor stops moving forward when going uphill....what's up?
   / New tractor stops moving forward when going uphill....what's up? #1
TaterinTexas
Waxahachie, Tx
NH 4.75, Case C80, Kubota B2100
I have a brand new New Holland T4.75. I was using it for the first time yesterday with a 6' rotary mower. Prior to buying this tractor, I used a case CX80. Anyway, I was mowing with no problems for several hours. I was running in low 3. I encountered a strange problem when I came to a little rise in the ground, it's maybe a 2.5 to three foot rise, although it is fairly steep. I had never encountered a problem climbing it before in my Case. But, with the NH, when I got to the rise, the tractor just stopped moving forward. The RPM's didn't change one bit, but it just quit advancing when I got to the rise. I clutched it and let it roll gently backwards, then eased off the clutch, tried to climb it again and the same thing happened.
I clutched it again, let it roll backwards, disengaged the PTO, raised the mower deck, then let off the clutch, and the tractor climbed the hill with no problem.
I am sure I'm not as knowledgeable as many on the forum, but I don't get what might be happening. Anyone have any ideas?
   / New tractor stops moving forward when going uphill....what's up? #2
My guess is the clutch is out of adjustment and it was just enough resistance when trying to climb the hill with the mower down to make it slip. If so, assuming it has a standard manual linkage clutch, it should be an easy adjustment.
   / New tractor stops moving forward when going uphill....what's up? #3
Are you sure you the front of the mower wasn't digging in? You said the rpm's didn't change but it did climb the hill with the mower raised. I'd remove the mower and try to climb it with PTO running. If no go, try it with PTO off.
   / New tractor stops moving forward when going uphill....what's up? #4
call the dealer and get him out to your place and show him. if its brand new let him worry with
That was my first thought too. But I looked at it the second time I tried it and it didn't appear to be the problem. Still, it was nearly dark, so I am going to go out this afternoon and see what happens when I try it again.
I'm hoping it's not the case that this is indicative of a lack of power. I knew I was dropping down in power a bit from my C80, but I didn't think 6 or 7 HP would make all that much difference.
1992 TRI CITY DUMP TRAILER (A58018)
1992 TRI CITY DUMP...
Compressor (A55973)
Compressor (A55973)
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52709)
(INOP) 2016...
Year: 2014 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A56859)
Year: 2014 Make...
Honda UTV (A56859)
Honda UTV (A56859)
