New Tractor Questions
   / New Tractor Questions #1
aaron9161
Jacksonville, Florida
I am currently looking for a new tractor. It will be used to clear about 10 acres (some of it is swamp), putting in fence posts, moving dirt around and maintaining the land. I am looking at a 1533 but should I go with hydro or power shuttle? The Massey dealer tells me that the 1533 is all that I need but the green and orange dealers try to talk me into bigger machines. Will the 1533 do all that I want?
Thanks
   / New Tractor Questions #2
The 1533 is a great little tractor. I had a 1433 for about 5 years. A 1533 should do everything you describe.
   / New Tractor Questions #3
!533 should be plenty, I have a 1528 and do about the same type of work on 15 acres.
   / New Tractor Questions #4
I also have a 1533 4x4 with 1525 Loader, it does a fine job. They are good Tractors.
   / New Tractor Questions #6
I personally would go with the shuttle shift, mine has the syncshuttle but I wish I had got the powershuttle so I wouldnt have to clutch it. Plus it is cheaper to.
   / New Tractor Questions #7
The powershuttle is not cheaper that the syncro shuttle the powershuttle is about a grand more.
   / New Tractor Questions #8
How have the power shuttles held up? Anyone have one with a lot of hours on? I drove one and really liked it, it was on an Agco ST34A, same as the Massey 1533 I am told. I was really leaning toward one but got talked into a Case DX40 with a hydro. I really like the frame size and comfort and looks of the Case, but think I like driving a gear shift better, although the more I drive the hydro the handier it seems to get (only have 10 hours on it), but I also wish I would have gotten a cab tractor. Plowed snow four times so far, froze my butt off three of the four. Also the loader on the case is first class IMO.
I called the Agco dealer to see about a cab tractor, hasn't gotten back to me yet he is having trouble locating one reasonably close. What do you think would I lose a lot on a trade?
JJ
   / New Tractor Questions #9
I looked at orange , green, blue and red. The green was to expensive,the orange didn't seem much interested and the red wanted to help me. I was looking for a smaller tractor 1532 size but when I saw and drove the 1533 it was all over but the shouting. That was it. It has all the power I need. It is comforatable and I think fuel efficent. I use it for all the things you mentioned and more. It is a great tractor and has not disapointed me yet and I am a little "rough" on equipment and it seems to take abuse ok. I like the clutch!
   / New Tractor Questions #10
Thanks
I know from your other thread that you already have your 1533, but I wanted to add to this thread for anyone using it to select a tractor. Not that I am an authority by any means, just sharing my thought process, however flawed it may be.
My dealer also suggested a 1533 based on my acreage and what I told him I would be doing with it. I decided on a 1547 largely based on the 1530 loader capacity compared to the 1525 loader. (1533 & 1540 tractor use a 1525 FEL, 1547, 1552 & 1560 tractor use a 1530 FEL)
My reasoning was: By moving up one tractor size (I know, skipped over the 1540 but it is the same size engine and frame as the 1533, more HP because of a turbo) I could increase to the greater lift height, weight capacity and breakout force of the bigger loader. I wasn't sure the difference in the numbers was worth it, but after seeing the two setups side-by-side on the dealer's lot, the obvious differences in the size and heft of the loaders convinced me there was a meaningful difference in construction.
Just my 2 cents, something others might want to consider. In the interest of full disclosure, I also wanted the Dyna QPS transmission, which is only available on the 1547 and up, so it wasn't only the loader capacity that swayed my thinking.
9202 (A50322)
9202 (A50322)
Forklift Safety Basket Attachment (A53421)
Forklift Safety...
1994 Aquasport Division boat with trailer (A55758)
1994 Aquasport...
UNUSED PROFESSIONAL X2600A ELECTRIC CONCRETE MIXER (A54757)
UNUSED...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2021 Ford F-150...
