Tractor Sizing New Tractor Question
   / New Tractor Question #1
spivey44
Atlanta, Ga
Kioti CK27
Currently on a Kioti CK27. Looking to upsize. I am considering the DK series. My implements are all 60 inch (flail mower, box blade etc.
The DK series Kioti are designed to handle I believe 72 inch implements. Any problem running a 60 inch mower on the larger tractor? Both tractors are Cat 1. I have been told I "should" buy larger mower as the 60 inch will be "inside the footprint"of the DK and therefore tires will compress grass resulting in a poor cut?
Any thoughts on this?
   / New Tractor Question #2
You won't have any problems running smaller attachments...but you won't be taking advantage of the increased PTO power.
You'll likely upgrade your attachments as time goes by...
   / New Tractor Question #3
You are always compressing the grass with the tires before you mow it. But without covering your tracks, you are compressing it a second time.
A work around for that is you can always use your sway links and offset the flail to the inside. That way, you cover that track.
PLEASE VIEW ALL PICTURES!! (A50775)
PLEASE VIEW ALL...
UNUSED JCT SKID STEER QUICK ATTACH 84" DOZER BLADE (A51244)
UNUSED JCT SKID...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
2016 Isuzu NPR-HD Morgan 24ft Box Truck (A50323)
2016 Isuzu NPR-HD...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
