New Tractor Owner, New to forum Kubota B7500
   / New Tractor Owner, New to forum Kubota B7500 #1
Memphis10
Kubota B7500
Hey guys, just purchased a new to me Kubota B7500, pretty clean tractor with 400 hours, 60” mmm, 2 sets of tires (turf and construction/ag) I believe it’s a 2006 year model. Also picked up a King Kutter 4’ rotary cutter the same day. But anyway, I’m a first time tractor owner but have grown up around my grandfather’s Ford 3000 and spent many an hour on it.
1. I’m thinking I should do a complete fluid/filter change
2. Remove mmm and clean/grease it, replace belt?
3. Replace seat: has anyone got a good seat recommendation? Saw one on EBay that had arm rests but wondered if they would interfere with lever operation???
4. Front wheel bearings: noticed today the front right wheel had a slight wobble. Are the bearing pretty easy to change or is that something that requires special tools and or a bearing press?
Anyways, thanks for any input/advice and I’m looking forward to putting in some work with this little tractor.
   / New Tractor Owner, New to forum Kubota B7500 #2
Unless you KNOW how it was maintained a completer fluid and filter change is always a good idea on any used equipment. It gives a known starting point. I'd clean and lube the MMM but unless it's bad I'd leave the belt for now. I won't address your seat issue at all. You say the front wheel has a slight wobble. You should check that out. It may be a bearing but could just as easily be a loose nut. You can get parts breakdowns for many Kubota tractors from the kubotausa website.
   / New Tractor Owner, New to forum Kubota B7500 #3
Kubota B7500
Kubota B7500 tractor photo
2000 - 2003
Series:B7400B7500
B7510
Production
Manufacturer:Kubota
Variants
B7500D:gear drive
B7500HSD:hydrostatic
Kubota B7500 Power
Engine:21 hp
15.7 kW
PTO (claimed):17 hp
12.7 kW
16 hp
11.9 kW (hydro)
Kubota B7500 Engine
Kubota 1.0L 3-cyl diesel
Mechanical
Chassis:4x4 MFWD 4WD
Steering:power
Brakes:wet disc
Cab:Two-post ROPS
Transmissions:6-speed gear
hydrostatic
Photos
Kubota B7500
Capacity
Fuel:5 gal
18.9 L
Front axle:3.4 qts
3.2 L
Hydraulics
Total flow:7 gpm
26.5 lpm
Tractor hitch
Rear Type:I
Rear lift (at ends):1,356 lbs
615 kg
Power Take-off (PTO)
Rear PTO:transmission (gear)
independent (hydro)
Rear RPM:540
Mid RPM:2500
Dimensions & Tires
Wheelbase:59 inches
149 cm
Weight:1323 to 1367 pounds
Front tire:6-12
Rear tire:9.5-16
Width:42.4 inches
Electrical
Ground:negative
Battery CCA:433
Battery volts:12
Page information
Last update:May 12, 2021
Copyright:Copyright 2021 TractorData LLC
Contact:Peter@TractorData.com
   / New Tractor Owner, New to forum Kubota B7500 #4
G'day Mate and welcome to TBN from Downunder.
As Roadworthy said, clean, lubricate (all grease nipples and, if it moves but doesn't have a dedicated 'zerk', spray it with a lanolin lubricant) the machine + implements and do a complete fluids change. Basically, trust but verify that maintenance has been done on your rig.
Enjoy the site... from wherever in the wold you are.
   / New Tractor Owner, New to forum Kubota B7500 #5
I replaced the seat on my B7500 with a Black Talon Cordura with armrests when they were on sale a couple of years ago. It is a tight fit on the B7500 but i have not had any problems with it.
The only issue I have with it is that it has a tall back with a headrest which makes it difficult to see behind the tractor. That is a problem when doing things like hooking up 3 point implements.
Thanks for the feedback fellas, are the service manuals and parts manual/books available for sale somewhere?
‘And hello from Memphis TN
   / New Tractor Owner, New to forum Kubota B7500 #7
Welcome Aboard ! I believe Tractor Supply sells replacement seats to fit several different models of Kubota. Just have to look-see. I bought a used B2150 which has a like-new seat on it that is not a Kubota part. I suspect the brand name Kubota seat is expensive and the TSC or other 3rd party seat would be satisfactory at much lower cost.
2017 INTERNATIONAL 4300 26FT BOX TRUCK (A43004)
2017 INTERNATIONAL...
2014 Dodge Charger Sedan (A44572)
2014 Dodge Charger...
New/Unused 30ft x 65ft x 15ft Storage Shelter (A44391)
New/Unused 30ft x...
WANCO 6K LIGHT TOWER (A45046)
WANCO 6K LIGHT...
NEW SIMPSON 3400 PSI PRESSURE WASHER HONDA ENGINE NEW SUPPORT EQUIPMENT (A40018)
NEW SIMPSON 3400...
STORAGE FEES (A43004)
