New tractor owner. Case international 1394
   / New tractor owner. Case international 1394 #1
Wayne hunter
England
Case 1394
Hi bought this tractor from a auction with broken turbo it was running but oil all over the engine anyway we decided to remove the turbo altogether so bought non turbo manifold blanked oil feed and return on block re coupled the air intake pipes now tractor running fine little bit of smoke out exhaust but hey the tractor is 26 years old but there is a slight weep of oil coming out of manifold. Has anyone experienced this before?
   / New tractor owner. Case international 1394 #2
You can't just take the turbo off and expect everything to be normal, the oil you see is likely un-burnt fuel.
   / New tractor owner. Case international 1394 #3
Welcome to TractorByNet!
We moved your thread to the Case-IH forum. :)
   / New tractor owner. Case international 1394 #4
there was a problem with that generation of case, there was too much oil pressure in the engine and it has to leak a small bit. mine leaks the speedo and all i do is keep it topped up. it is very important to keep it high with oil if it is a hydro-shift gear box.:)
   / New tractor owner. Case international 1394 #5
Mine leaks oil as well. Also keep it topped up and haven't had an issue in the 5 years I have owned it.
2004 Kenworth T800 Day Cab T/A Truck Tractor (A52377)
2004 Kenworth T800...
Killbros 260 Seed Conveyor (A53472)
Killbros 260 Seed...
20ft Bi-Parting Gate (A51573)
20ft Bi-Parting...
2011 John Deere 5075 4WD Agricultural Tractor (A52377)
2011 John Deere...
2019 CATERPILLAR 289D3 SKID STEER (A51246)
2019 CATERPILLAR...
