New Tractor for buyer new to tractors
   / New Tractor for buyer new to tractors #11
I thought BC was all MKS
Shouldn't those acres be hectares?
eta
Get the B-01, skip the cab, You need the air and sunshine!
Get a box blade, and a scrape blade, and a flail mower. $$$$
oh! don't forget the carry all.
As a self test, write down the four things you NEED to have a back hoe to do.
If the value adds to MORE than the cost, buy one. If less, RENT!
   / New Tractor for buyer new to tractors #12
You are right there about the new ridiculous prices.
Anyway, I see you want to stay in a budget, so the B2601 will do everything you need.
I see the usual "go bigger" "get a cab" responses, and yes that is all well and good, but the B will do everything.
Mine has never let me down.
Here's some of my useless advice:
1. Backhoe. Wish I never bought mine, would have been better to put that 10 grand towards a mini-ex. But that was when a mini-ex was still affordable.
My gripe with the backhoe on my B, is the tractor is light and the hoe will easily pull it around. And because of it's short reach, you spend more time repositioning than you do digging.
BUT it beats hand shovelling any day.
2. Definitely get the B over the BX.
Better ground clearance, stronger, easier servicing when it comes to fuel filters and fan belts.
3. The LX has a bit more capacity than the B, but it costs more, has more electronics, and in the case of the LX2620, no way I'd trade my B 2620/2601 for one of those because the whine from that transmission would drive me mental. Only the 35 and 40 horse versions got the improved transmission, but again....way more money and a DPF and regens.
   / New Tractor for buyer new to tractors #13
Definitely agree with the 'skip the backhoe' advise either way. You can always get a mini-ex, and even the mid-tier Chinese ones (sacrilege!) will do more and be easier to use and move than the backhoe.
   / New Tractor for buyer new to tractors #14
It's hard to explain, but the backhoe comes down to how much do you want to spend? Like I said, I should have bought a mini-ex, and I would probably undertake more projects if I had one. My backhoe sits unused every year. Think I've used it 3 times.
BUT those three times I was sure happy I had it. Didn't have to wait to rent a machine and didn't have to shovel.
But then back to the negative....I could have rented a mini-ex many times with the 10 grand I spent on the backhoe, LOL
   / New Tractor for buyer new to tractors #15
And isn't that crazy.....how a B2601 TLB can be $60,000 Canadian now? Just as covid was starting I could have got a Grand L3560 cab with loader and rear snowblower for $50,000. Now it's $86,000 here.
No thanks.
   / New Tractor for buyer new to tractors #16
I have an open station tractor, Kioti CK30HST with FEL, and I enjoy the open air over a cab. It's not like I'm a fulltime farmer and need weather protection every time that I use it. Plus it's not affected as much in the woods by low hanging branches. I use it to blow snow, cut grass, push dirt/debris, lift things, carry firewood, cultivate a foodplot, etc.
Store your tractor out of the elements, be diligent with maintenance and fuel storage, and don't EVER lend it out to neighbours unless you come with the package!! 10 years down the road you will get your money back should you need/want to update.
It's nice to have a dealer close by, but don't be limited by that too much.
Keep us posted
   / New Tractor for buyer new to tractors #17
Keep us posted
ESPECIALLY the neighbour thing!
   / New Tractor for buyer new to tractors #19
I was looking at an L (L4802), but the price difference between the MX5400 and the L4802 was negligible after adding a 3rd function and two rear remotes. I really like how the MX has the bigger front tires and axle. Take a look at the MX. I would also recommend a flail mower instead of a bush hog.
   / New Tractor for buyer new to tractors #20
TANK MANIFOLD (A55745)
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2012 CM  T/A ENCLOSED 14 TRAILER (A55745)
2012 CM T/A...
2011 ELITE TRAILER 20 T/A GOOSENECK (A55745)
2011 ELITE TRAILER...
2018 FREIGHTLINER CASCADIA SLEEPER (A56138)
2018 FREIGHTLINER...
28013 (A50322)
28013 (A50322)
