Buying Advice New Tractor Delivery Hour Meter
   / New Tractor Delivery Hour Meter #51
My new Kubota had 2.4 hours at delivery which I figured was - loading, unloading, FEL instal & testing and generally getting a new machine ready for delivery. Hmmmmm - - almost ten days and not a peep. Does make one wonder.
   / New Tractor Delivery Hour Meter #52
That's a cool piece of info that I did not know. I thought that my hour meter seemed to run a little "slow". Thank you.
I don't think that's universal. Some run at the same rate independent of engine RPM.
   / New Tractor Delivery Hour Meter #53
Seems most construction equipment runs on a Hobbs type meter, independent of RPM. I think many of them have a system that keeps the hour meter from gaining time unless the engine is running. I think it may use the oil pressure switch to close the Hobbs meter circuit. Most ag tractors are rpm dependent, which actually is a good thing in my opinion as it more closely reflect that amount of work done with the machine.
   / New Tractor Delivery Hour Meter #54
Well, now I am going back to double-check, but I thought my Bobcat (a.k.a. Kioti) was independent. But Kioti is certainly an ag-style tractor more than a construction equipment.
   / New Tractor Delivery Hour Meter #55
I think if you idle your Bobcat/Kioti at 1100rpm for an hour, it will only show 1/2 hour gained.
I have heard it said that the best indicator of actual work done is total fuel used. Not that we have a meter for that cumulatively, but it makes sense. You can run a tractor at PTO RPM with a light load and it will show an hour for an hour, or you can run it at that speed at 100% of it's potential HP being used (like tilling or mowing with a large implement and fast ground speed) and it still shows an hour, but it was a mighty tough hour with the temps up and working very hard. In one case you used 1/2 gallon, in the other you used 2 gallons. Interesting concept.
   / New Tractor Delivery Hour Meter #56
How does the hour meter work on a Mahindra?
   / New Tractor Delivery Hour Meter #57
Based on engine RPM like most ag tractors. Some are mechanical, some take an electronic signal off a rotating part like an alternator.
   / New Tractor Delivery Hour Meter #58
DavesTractor, Spot on. It is a favourite saying of mine when I especially agree with somebody. I am close to the 2500hrs service on my tractor. I pay the NH dealer I bought it from to service it every 250hrs because someday I will sell it through him. The first 1000hrs was clocked up in a few months and I have had the machine eight years. The first 1000 was almost flat out with a stone rake I built and then removing the stone with another home built piece of equipment. Since then it has been mainly light work, and I use very little fuel compared with the first year.
   / New Tractor Delivery Hour Meter #59
My wife got a new Kubota last month and it has 0.1 hour on it and that's where she drove it around the lot. To me new is less than 1 hour. I feel if it has more than 3 hours it must be used. We had a choice and the other one had 5 hours on it but it also had grass under the deck and dust everywhere and nicked blades. I felt like it was used.
Took delivery of a 1026R yesterday, had 0.5 hrs on it. The one delivered earlier this year (May) had less than 2 hours, think it was 1.5. To me those were "new". Even if it had only been at the dealer or at shows/displays, when you start getting 10-20 hours on something, in my opinion it is used or a demonstrator. As has been stated, you most likely won't know how those hours were incurred or who put them on. I'd certainly ask for a concession on the price. Just my thoughts.
A thousand apologies to all concerned.
When it finally arrived it had 1.6 hours on the clock.
I found that to be an acceptable amount of time.
What say you, Guys?
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2024 ArmorLite Aluminum End Dump Trailer (A56435)
2024 ArmorLite...
2018 Ford Escape SUV (A56859)
2018 Ford Escape...
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
2010 Specialized Structure 1456 (A56858)
2010 Specialized...
JLG SCISSORLIFT (A52705)
JLG SCISSORLIFT...
