New toys
   / New toys #11
Jim-
I have a 55 gal. 3pt. spray rig with boom and wand. Very handy.
<font color=green>stan</font color=green>
   / New toys #12
<font color=blue>I have a 55 gal. 3pt. spray rig with boom and wand. </font color=blue>
Perfect!!! /w3tcompact/icons/smile.gif
That's high on my wish list, and it sounds like I drive right by your place on the way to my tractor property. Think it will fit in the bed of my mid-size pickup truck? /w3tcompact/icons/wink.gif
More seriously -- any chance you could post a picture of your rig? Also, did you buy it locally?
   / New toys #13
Harv-
Sorry, I don't have the equipment or expertise to send a pic, but will get a brochure for you. Got it from PBM in Chico. You basically "design" it yourself (with their help). You can select the type/size of boom(s), wand, pump, nozzles, valves, etc., and they will build it to your specs.
Looking forward to getting some Surflan and Simazine down before the October rains. Pre-emergent herbicides are the way to go on non-crop areas and around established plantings. Will send private.
   / New toys #14
<font color=blue>Got it from PBM in Chico.</font color=blue>
I picked up the PBM brochure from Green Valley Tractor a while ago. Nice-looking stuff.
Guess I'd just better start saving up pennies.
Thanks, Stan. /w3tcompact/icons/smile.gif
   / New toys
Well there's a story behind that ballast. Before I put that on there I was leaving some undisturbed soil in between the disks in some places. Thats a piece of concrete left over from when they poured the slab on my shop bldg. It was heavy - probably over 100 pounds.
I was almost finished when I heard a noise, looked back and saw that the "rock" had fallen down in between two inner disks and none of the disks would turn. After about 20 minutes of prying I finally got it out and mashed my little finger in the process. Its black and blue but fortunately it didn't break it. I would have cussed but nobody was around to appreciate it...
I'm happy with the way the disk performed. It would have taken way longer to till what I went over with the disk. Of course it doesn't pulverize it like a tiller does, but it breaks it up 3 or 4 inches and thats all I wanted. And its fast. Now I need a single bottom plow to go along with it for the garden.
By the way, the ground was not the real hard dry stuff we are used to in the late summer, so the disks dug in pretty good with the added weight. If the ground is real hard it might need more weight. Some of the ground had some vegetation on it and it did a pretty decent job on that too, especially when I made a second pass. I used the disk with the pedal floorboarded in medium range, and the 2710 never grunted at all.
The disk has 16 grease fittings that held almost 2 whole cartidges of grease before I got started.
As for the PTO shaft, I had hell with it. The plastic guard on the outside makes it virtually impossible to hold onto it while you cut it with a hacksaw. After cutting the inside shaft about 2" and trying to put it back I discovered that didn't do any good and that I would have to cut the outside shaft also - and the plastic guard. I have very sore shoulder, a slightly torn rotator cuff I think, and sawing with a hacksaw with it flopping in the breeze was difficult. Since my wife was there helping me hold it, I went ahead and let out a few expletives and it helped a lot. The bottom of the spreader is supposed to be 70 to 80 centimeters, which I guess is 56" to 60". When I started I could only get it about a foot off the ground. After cutting the shaft I got up to maybe 36" and I did the whole job that way because my hacksawing shoulder was done. So my swath was only about 25 feet or so, the book says it should cover a 40 foot swath. I plan to cut it off another 2" before I use it again. Maybe I'll let my 22 year old son do the honors since he ain't ruint his shoulder yet.
I really like the spreader and, man does it sling that stuff out there. the settings aren't accurate. I set it up the way I though it should be and it threw out 50 pounds in about 20 seconds, so I cut it way back and had enought to make second passes the other direction. I look forward to using this thing alot.
Alan L., TX
   / New toys #16
He's talking about shortening the driveshaft, not cutting off the shaft sticking out the back of the tractor.
   / New toys #17
Alan, one word. Sawsall.
   / New toys #18
Sawzall sure is the way to go, if you have one. Very handy for exhaust work on your car or truck too, I might add.
   / New toys #19
Lono
Railroad rail is weighed per 3 ft..Rail is classified by "pounds", for example 133lb rail is 133lbs per 3ft.Most modern rail is between 133 and 140 pound..I hope this clarifies this matter
Hoghead
   / New toys
Well I'm disappointed that one of you guys didn't jump on my poor arithmetic. 70 centimers is actually about 28 inches (not 60 inches - about 2.54 cm per inch), so I guess I really have the spreader at the right height already.
Alan L., TX
NEW Wolverine 72in Skid Steer Ripper (A59000)
NEW Wolverine 72in...
2014 VOLVO VHD DAYCAB (A58214)
2014 VOLVO VHD...
2019 Ford F-350 (A55973)
2019 Ford F-350...
LOT: Fill-Rite Pump, Fuel Transfer Tank, Tool Box (A59076)
LOT: Fill-Rite...
2013 CATERPILLAR 316EL EXCAVATOR (A52709)
2013 CATERPILLAR...
2024 DIGMASTER MINI EXCAVATOR (A58214)
2024 DIGMASTER...
