new toy
/ new toy #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
I picke dthis up this weekend, and almost forgot to talk about it.
I had been wanting to get a seeder / spreader to do some planting, but most of the units I saw were huge.. and I wanted to get something that my New holland and my smaller yanmar could use. I found a spreader at tractor supply. 3pt mount, and it uses a flexible pto shaft.. rather ingenious ( hope it lasts ).
Nice setup... light enough to pick up and mount by yourself, especially if the wife slides the lock pins in for you.
My wife used to be anti tractor.. but I try to include her with it, to get her used to it.
She won't actuallyuse it yet, but if we are driving around and she sees an impliment I don't have, she points at it and says
'do we need one of those ?'
If I finish discing the pasture this weekend, i may seed it too. If so, I;ll post about the spreader. I believe it holds about 1.5 bushels of seed.
Anyone have any experience with these, and know any do's/don'ts?
Chris
Chris
/ new toy #2
Not sure which spreader you have, but I picked one up from Agri Supply that has a 350lb hopper that is about right for small tractors. It works great and is not as big as the larger units. It is a good fit on my 1720D.
/ new toy #3
I've had one of these similar to what you describe for about 12 years. It doesn't get very heavy use. The flexible shaft has given me no problems. I give it a shot of grease about every other time I use it. One thing you have to look out for is to make sure you wash it out thoroughly after using it to spread fertilizer.
/ new toy
Thanks for the info. I didn't look close at the time, but do these normally have grease fittings? Or is it just a grease it where it moves/joins thing?
As for fertilizer.. It looks like the manufacturer expected corrosive materials to be in the hopper... there must be 1/16th inch of the 'cat' yellow ruberized paint on this thing.
Chris
2018 LANDOLL 330 S/A  DROP DECK TRAILER (A59912)
2018 LANDOLL 330...
2018 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2018 Volvo VNL T/A...
2016 Peterbilt 579 Automatic High Top Sleeper (69") (A62613)
2016 Peterbilt 579...
UNVERFERTH HT25 HEADER CART (A63291)
UNVERFERTH HT25...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 INTERNATIONAL...
Caterpillar 12H/140H/160H Motor Graders Service and Parts Manuals (A63117)
Caterpillar...
