New tools?
/ New tools? #1
RollTideRam
Hartselle, Alabama
Kioti DK 4710 Cab
I have been wanting to get a 3/4 inch socket set lately. I will probably go cheap with harbour freight or TSC. Will I need standard or metric is the question. When tightening or changing out the pins on my implements I'm tired of using my giant adjustable wrench. The largest bolt I have run into on my 3320 was 15/16ths so far. I'm sure a metric equivelant would have worked also. JC
/ New tools? #2
Yes.
You will unfortunately need both to work on the tractor AND implements.
/ New tools? #3
As kennyd says, ideally both standard and metric would be best, but once you get to 15/16" and larger, usually a standard socket will fit a metric bolt and vice versa. Especially if you go with 6 point sockets. a 15/16" will fit a 24mm, a 1 1/16" will fit a 27mm, a 1 3/16" will fit a 30mm, a 1 1/4" will fit a 32 mm... Slight differences in size are not as critical as in the smaller sizes. Personnally, I only have a standard 3/4 set. I figure if I run into a metric size that won't interchange, I'll buy an individual socket. Call me cheap I guess.
IRRIGATION FITTINGS, PIVOT WHEELS (A64276)
IRRIGATION...
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
UNUSED ATSPOWER ELECTRIC WINCH (A64281)
UNUSED ATSPOWER...
2022 CATERPILLAR 262D3 SKID STEER (A62129)
2022 CATERPILLAR...
BUSH HOG 6' ROTARY MOWER (A64280)
BUSH HOG 6' ROTARY...
UNUSED WOLVERINE JMR-22-85G RIPPER (A64281)
UNUSED WOLVERINE...
