New tools?
   / New tools? #1
RollTideRam
Veteran Member
Hartselle, Alabama
Kioti DK 4710 Cab
I have been wanting to get a 3/4 inch socket set lately. I will probably go cheap with harbour freight or TSC. Will I need standard or metric is the question. When tightening or changing out the pins on my implements I'm tired of using my giant adjustable wrench. The largest bolt I have run into on my 3320 was 15/16ths so far. I'm sure a metric equivelant would have worked also. JC
   / New tools? #2
Yes.
You will unfortunately need both to work on the tractor AND implements.
   / New tools? #3
As kennyd says, ideally both standard and metric would be best, but once you get to 15/16" and larger, usually a standard socket will fit a metric bolt and vice versa. Especially if you go with 6 point sockets. a 15/16" will fit a 24mm, a 1 1/16" will fit a 27mm, a 1 3/16" will fit a 30mm, a 1 1/4" will fit a 32 mm... Slight differences in size are not as critical as in the smaller sizes. Personnally, I only have a standard 3/4 set. I figure if I run into a metric size that won't interchange, I'll buy an individual socket. Call me cheap I guess.
Ford XTRA-VATOR 555D Loader Backhoe (A55787)
Ford XTRA-VATOR...
2014 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400 LB Crane Service Truck (A53422)
2014 Ford F-550...
Massey Ferguson 231 (A53314)
Massey Ferguson...
2010 MULTIQUIP 25KW GENERATOR (A53843)
2010 MULTIQUIP...
2018 Ford Fusion Sedan (A55758)
2018 Ford Fusion...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
