New to Yanmar tractors and need some assistance
   / New to Yanmar tractors and need some assistance
Final Chapter on the Yanmar tractor or at least for now. I drained the fluid and cleaned the filter then disassembled the fluid pump. There was a broken O ring and the nut was off the connector of the impeller shaft. Replaced the nut, (which was laying in the connector part) and the O-ring. Filled it with fresh fluid and it now works just fine! Turned out to be an easy fix. Thanks for the advice guys. Best, Dave
LOT: (1) Steel Plate Sheet, 1/4" Thick, 48" x 96", (1) Steel Plate Sheet, 1/4" Thick, 41" x 96" (A59076)
LOT: (1) Steel...
5PC. WICKER SET (A58374)
5PC. WICKER SET...
525 (A52708)
525 (A52708)
20 BLADE DISC HARROW (A52708)
20 BLADE DISC...
LOT: (3) Sections of Steel Pallet Racking Welded Together: (1) 9' W x 9'H x 48" D, (1) 9' W x 7' ... (A59076)
LOT: (3) Sections...
202475 (A54757)
202475 (A54757)
