New to the forum
   / New to the forum #1
twood78
PowerTrac PT-425
I was bitten by the Power Trac bug back in 1998 when I bought my 422. Hardest-working little machine ever built. Bought a custom trailer rig in July 2016 to house all the toys. I needed an upgrade, so I sold the 422 and bought my 425 in February 2017. I like the 425 better because of the extra power and reach, and the treadle is a huge improvement.
The Subaru/Robin engine has, unfortunately, not improved. Actually gotten worse. The fuel shut-off solenoid in the carburetor failed to work on my first job and flooded the engine on the jobsite twice. Also vapor locks every time it is worked hard in warm weather. Solved the fuel shutoff problem by adding a solenoid valve in the fuel line (redundant). Attempted to solve the vapor locking by replacing the mechanical fuel pump with an electric one under the tank, but the problem persists. Taking her back to Tazewell to see Terry next week for some head-scratching and heat shielding.
I really love these little machines and the folks in Tazewell, but this problem's gotta be fixed...
   / New to the forum #3
Welcome.
Consider adding a fan to the right side of the tub blowing across the exhaust. The hot weather fueling problem is a "known issue" with the Subaru and I'd be shocked if PT has a solution...other than swapping in a Kohler.
I had the same problems as you with the POS Robin 25HP. Only, in my case, the needle valve (I think mine didn't have a shut off solenoid) flooded the engine when I left the tractor setting for a few days. Now, one is "supposed" to check the oil before each start up. This is one of the reasons why. If I'd done so, I would have noticed the high oil level due to the extra fuel getting past the piston rings and would not have killed my engine when attempting to start the thing. Even so, good riddance. I hated that engine. Replaced it with a Subaru 35HP engine that's made by Generac. But that's a whole different story.
Anyway, the fan should help (but may not completely fix) the fueling problem.
   / New to the forum #4
Don't know if it would help you or not, but on my Kohler, when the mechanical fuel pump died from a torn diaphragm, and I found a new one was ridiculously high priced from everywhere, I replaced it with a vacuum fuel pump quite inexpensively. There's a thread on it here somewhere. I tapped the vacuum off of the valve cover, where I gutted the mechanical one from.
Oh, and welcome to TBN! :thumbsup:
   / New to the forum #5
   / New to the forum
Thanks for the welcome! I've done about everything imaginable with the PT400 series except climb trees and prevent vapor lock. My current set-up is a 425 on a trailer rig housing it (love the quick-attach plate mounting) along with 10 cu ft bucket, box blade, 48" mower, forks, auger head with 6" and 12" augers, trencher, concrete mixer, winch, and hitch plate. Visiting Tazewell next week to add a trench filler, larger concrete mixer, and some heat shielding for the vapor locking.
Terry acts surprised that I am experiencing vapor lock, but has offered that they can install some heat shielding that will help. The PT425 has serious heat management issues. After normal operation and parking of the tractor, the fuel shutoff valve in the carburetor will close, but the heat soak will cause the carburetor float bowl to boil dry. This makes it difficult to start at the next use (rough on starter and battery). Installation of a primer bulb or electric fuel pump solves this problem nicely. All the heat, however, soon had my primer bulb cracking, so I replaced it with an electric fuel pump. Vapor locking is still happening, however, and the primer bulb made recovery much easier and faster than the electric fuel pump. If heat shielding doesn't work, a high-pressure/high-flow fuel pump with 4 psi spring-check valve on a return line to fuel tank will keep the fuel cool and liquefied, or a secondary cooling fan might be in order. How much electrical load can these engines sustain?
   / New to the forum #8
:welcome: to TBN...enjoy.
   / New to the forum #9
I do not know about the electrical load. My 2001 Kohler has only a 15 amp alternator. Don't know about the other engines.
2015 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A52377)
2015 Peterbilt 579...
2005 Caterpillar 430D 4x4 Extendahoe Backhoe Loader (A51691)
2005 Caterpillar...
2022 John Deere X9 1100 Combine, (A53342)
2022 John Deere X9...
2025 New/Unused 72in Skid Steer Brush Cutter (A51573)
2025 New/Unused...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2013 Ford F-150...
WOODS RT48.30 LOT NUMBER 235 (A53084)
WOODS RT48.30 LOT...
