New to site. Thanks in advance for your help.
   / New to site. Thanks in advance for your help. #1
Bluehat
I own 2006 JD 2305, having a start issue, motor turns over great, new battery and cables, having to move low/high range lever to find neutral. Where is the neutral/safety switch?
   / New to site. Thanks in advance for your help. #2
Not sure on that one. On my JD2520 it is located on the left side of the tractor-just in front of the rear axle. If you lay down on the ground and have someone move the shift lever back and forth you should be able to find it. I know where mine is on the 2520 because the first time I took it in the woods to do some light skidding a branch on the ground 'nudged' the neutral safety switch aside such that the tractor wouldn't start! IIRC, however, it wouldn't crank at all ...
Good Luck.
Frank
   / New to site. Thanks in advance for your help. #3
Welcome to the forum. :welcome:
Sorry to hear about your start issue. I'm going to move your thread on over to the JD section in case you still need some more advice.
2005 Kaufman Trailers Trailer, VIN # 15XFW53265L001140 (A53421)
2005 Kaufman...
2007 Ford Ranger Pickup Truck (A50323)
2007 Ford Ranger...
MCELROY COOL PACK 20 (A53843)
MCELROY COOL PACK...
2010 Ford F-750 Stellar 10621 10,000LB 5 Ton Crane Mechanics Truck (A51692)
2010 Ford F-750...
2018 SkyJack SJ1056TH 4x4 Rough Terrain Telehandler (A52377)
2018 SkyJack...
Ford 3600 Tractor (A53117)
Ford 3600 Tractor...
