New to site. Need some expert buying advice
   / New to site. Need some expert buying advice #1
sloretto
CT
Hello Everyone!
I am looking to buy a riding mower tractor for a 1.5 acre property. My wife and I are expecting our first child in august and decided to move out of the city to the burbs in CT. I always wanted a riding mower and have been looking into purchasing one. Have checked out Cub Cadet, Husq, Craftsmen, Arien, and some others.
I am hoping someone can give me some buying advice. My budget is $1500.
Thanks!,
Stefano
   / New to site. Need some expert buying advice #2
In that price range,they are all the same,just different names and colors,so go buy the cheapest one.
Now if you wanted to spend 3-5 thousand,you'll have more meaningful choices.
Not an expert by the way.
   / New to site. Need some expert buying advice #3
"In that price range,they are all the same,just different names and colors,so go buy the cheapest one...."
While some will argue up and down against that, I totally agree. Not much difference in most of them except for the price tag.
Three years ago I was looking for a rider and spent some time checking all the different makes out. Dad had bought a 20hp JD riding mower a few years ago so I was familiar with their product but it wasn't all that much more impressive than the 18hp TroyBilt (MTD) that I bought for $1k at Lowes. Three years on I've had to replace the blades 3 times (rough lot, put severe duty blades on this last time and they are great) and a new battery this spring. Otherwise, couldn't be happier no matter how much money I would have spent. We have a one acre lot that gets cut 2-4 times a month 8 months out of the year so it's seen a fair amount of use and held up very well.
thank you for the advice. I was tempted to spend more $$, but I realize i have small yard with seasonal cutting needs, so can't really justify the expense of better quality mower. Thanks again!
Stefano
   / New to site. Need some expert buying advice #5
Stefano
Four years ago a bought a Huskee riding mower with 42" deck from Tractor Supply for $899. At the same time I bought a 4-year service plan from TSC for $125 or so. This is the 5th season. No problems with the mower. I did use the service plan once to have an electrical problem fixed (battery not fully charging). No cost. Now I just keep the battery on a trickle charger. Works fine.
No need to spend thousands on a JD, Toro or other expensive mower unless you go for the snob appeal. I figure if I get 5 or 6 seasons out of that Huskee cheapie, I'll be money ahead.
   / New to site. Need some expert buying advice #6
Not An Expert...But my story/ backround is alot like yours so I wanted to throw my 1 Cent in. (I dont even know enough for 2 cents)
Not to repeat everyone, but I recently did the research, and I tried to work within a 2000 budget. It was tough, I ended up well above that.
but to stay in your range, I don't know much more than craftsman that will be a good buy. Stay away from extra bells and whistles, look for Engine / deck size to be a good deciding factor.
If you are just mowing a lawn, the options are meaningless. I'VE heard that the "John Deere" sold at Home Depot are not worth the $$ b/c you are buying the name (when in reality those are below grade to be called a "DEERE")
Good Luck with Baby/Wife and Tractor.
   / New to site. Need some expert buying advice #7
If you are just mowing a lawn said:
I can attest to this on my last property (just under an acre) I bout a JD from Home Depot for over 2k. Nothing fancy just buying the name, (didnt know any better at the time) + this was my first riding mower. My neighbor at the time had a Craftsman rider from Sears and spent about 900 on his new and there was really no differnce in the tractors except the name and the deere had a bagger that could have been purchased seperatly (for another 3 hundred) I agree w/ others in this price range not really much of a difference. Good Luck
   / New to site. Need some expert buying advice #8
Thought about used? Might be able to get a slightly used quality tractor versus a not so great new one in your price range. :eek:
   / New to site. Need some expert buying advice #9
The BEST deal on a BBS Tractor is the one with the lowest price .
Valvoline 6 cases manual transmission oil plus 11 (A53117)
Valvoline 6 cases...
Bobcat Sweeper/Bucket  72"  (A52384)
Bobcat...
2001 Kubota L3010 (A50123)
2001 Kubota L3010...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
2025 K731G UNUSED Flower Bed (A53117)
2025 K731G UNUSED...
Trojan 50CL 40mm Hydraulic Hammer, New  (A52384)
Trojan 50CL 40mm...
