Rake New (to me) York Rake (pics)
   / New (to me) York Rake (pics) #1
257NH
New Hampshire
New Holland TC40DA
I've been looking to pick up a lanscape rake and actually was in the process of ordering a heavy duty 84" king kutter from TSC but they were going to charge me freight because they deal with farm force up here in NH.I told him to suspend the order and the next day I found this one.
http://i147.photobucket.com/albums/r287/257nh/yorkrake2.jpg
http://i147.photobucket.com/albums/r287/257nh/yorkrake.jpg
Its in pretty good shape,3 or 4 bent (straight back) Tines. Can you straighten spring steel without heat or do I need to replace them?I'm really impressed with how heavily built it is.Its also got the flip down grader blade.First thing is going to be to get some tubes in the tires and pump them up.
I also got some railroad track from my neighbor,It will eventually be turned into a counter weight in conjuction with my ballast box.There are 2 6 foot pieces.
http://i147.photobucket.com/albums/r287/257nh/track.jpg
   / New (to me) York Rake (pics) #2
Nice find on the rake. As far as the tines go, you should be able to pull them strait with a piece of pipe that will fit over the tine, and grunt them into shape. I would stay away from heat until you try the 1st option, just my .02cents.
Thats what i was thinking.I'm reasonably sure that if I heat it up all bets are off whether or not it will still be spring steel or not.
   / New (to me) York Rake (pics) #4
Yep, that's where I was going on this. We used to straiten digger links on spud diggers with a simple conduit bender before heat was ever used. Granted digger links aren't spring steel, but, the temper and make up of the link didn't like the heat vs. the "cold" manual brute force of re-shaping it. The heat seemed to make it weaker in the long run.
Thanks for the advice JJ.I fooled around with the rake a little today.Wire wheeled the inside of the wheels and installed slime filled tubes.Its now up and running.
http://i147.photobucket.com/albums/r287/257nh/yorkrake3.jpg
The RR track is cut up and waithing to be installed in the counter weight,Next time a cement truck comes here I'll finish that up.
I fooled around with the rake on a stripped lot today and got the top link adjusted to my liking.Even messed around with the drop down blade.Seems to work ok as long as its not to heavy a job.Certainly moves more material than the teeth anyway.All in all I'm very pleased with it.I'll keep it unless I find A used model RI from york,this ones an RW
   / New (to me) York Rake (pics) #6
nice find. I've been looking for a used one for awhile, with no luck. I am not sure, but I think you can buy those tines alot of places online and maybe TSC sells them too.
   / New (to me) York Rake (pics) #7
if you do heat, heat and bend, let it cool a little, then heat again but not as hot this time, this seems to help with the strength.
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A53426)
PEMBERTON...
2012 Ford F-250 Pickup Truck (A51692)
2012 Ford F-250...
2011 Land Rover Range Rover Sport AWD SUV (A51694)
2011 Land Rover...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
