New to me Simplicity, need help identifying
   / New to me Simplicity, need help identifying #1
Kegomatix
Scio, OR
Simplicity
So today I got for what I consider a good price, a "new" tractor. It hadn't fired ran in 5 years when it was parked indoors. Today we aired up the tires, put some gas in it, and jump started it and it fired up great. Was able to drive it right up on to the truck.
Anyhow, I'm not really sure exactly what it is. The previous owner said he thinks it's a 68 but isn't entirely sure.
It's got a hydraulic leak somewhere, the blade won't stay in the upright position, it'll slowly lower itself back down. Other than that it mainly just needs cleaned up and a lot of maintenance. Not bad for free.
   / New to me Simplicity, need help identifying #2
Your tractor looks to be 67 68 Landlord . Your cylinder seals are leaking by. that is if you don't find any puddles on the ground.
Dan
   / New to me Simplicity, need help identifying #3
Try doing some research here: http://www.simpletractors.com/default.htm
Your tractor has been repainted and other changes are likely over the years, so it would take a while to pin down exactly what model it is. The easiest way to "date it" would be to identify the engine by model number - but that only works if someone hasn't changed the engine, some time over the last 45-50 years...
   / New to me Simplicity, need help identifying #4
That was made between 1965 to 1967. 1968s were different. Good tractors, I have one. Too bad the tiller pulley has such a bend in it.
2021 JOHN DEERE HX14 (A53084)
2021 JOHN DEERE...
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
2004 FREIGHTLINER COLUMBIA (A53843)
2004 FREIGHTLINER...
2015 Hitachi PC138 (A47477)
2015 Hitachi PC138...
