new to me John Deere 5410 "high hours ?"
   / new to me John Deere 5410 "high hours ?" #1
cshannon33
I just brought a John Deere 5410 at an Auction, it seemed pretty tight, very little wear on the clutch pedal or floor board. I just glanced at the hours, thought it said 1750, after I bought it and was loading I noticed the hours were 17502.8, The engine tag says 2001 model; how could a tractor get that many hours and not be worn-out? There is a little slack on the PTO shaft and seal needs replacing, but it's not bad. Very, very little smoke (normal). There is also a "sentinel" something mounted on the side, it has 4 lines running up to the water jacket. it's about 2 inches round and 6 inches tall; any ideas on what this does? My best guess is that it was on a catfish pond, but still 17000 hours? Like said the tractor seems pretty tight, no problems so far, (only ran about 1 hour, light bushhogin. Any ideas, also what problems might be on the horizon? I'm thinking about putting a Koyker loader on it; is this loader OK?
thanks for the help!
   / new to me John Deere 5410 "high hours ?" #2
Are you sure it said 17502.8? Often there's a little hourglass symbol on the hourmeter that could possibly be misinterpreted for an 8...
Anyway, if it came from a catfish farm, I'd bet it spent a good deal of time hooked up to an aerator pump or something like that... Lots of hours running the pto as a stationary power unit.
I was watching the hours as I ran it that little bit, I wish it was but it's not an 8. I also timed the tenths, there are right at 6 minutes apart at normal PTO speed. so i'm guessing the hour meter is correct.
   / new to me John Deere 5410 "high hours ?" #4
I agree, sounds like it ran an aerator and flush/fill pump for many hours on end. As for the loader, I like my Koyker 185 loader much better than the BushHog 2846QT on my 7610.
   / new to me John Deere 5410 "high hours ?" #5
And here I was told these new tractors just don't last! Landfill candidates all!:confused: :confused: :confused:
Course it's a John Deere, might have something to do with the buncha hours it's managed to survive!:D :D :D
Back where I grew up there are lots of them on the farms!:D :D :D
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A56129)
2021 MACK GRANITE...
2022 New Holland C327 Compact Track Loader (A55302)
2022 New Holland...
Dry Gel Hydration Unit (A55745)
Dry Gel Hydration...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51692)
2017 Mack GU713...
2012 Chevrolet Impala Sedan (A54815)
2012 Chevrolet...
1998 FREIGHTLINER CST120 TANDEM AXLE SLEEPER TRUCK (A56129)
1998 FREIGHTLINER...
