New to me jd 755 has no front hydraulics , apparently a base model, is it worth retrofitting ports and controls
   / New to me jd 755 has no front hydraulics , apparently a base model, is it worth retrofitting ports and controls #1
Jd-lox
Jd 755
jd 755 has No front hydraulics, is it worth retrofitting. Runs perfect, 3 point works perfect
   / New to me jd 755 has no front hydraulics , apparently a base model, is it worth retrofitting ports and controls #2
We need more info. Do you need front hydraulics? Can you do the installation yourself? Can you find the kit somewhere? For sure that JD won't stock it anymore.
   / New to me jd 755 has no front hydraulics , apparently a base model, is it worth retrofitting ports and controls #3
Unfortunately JD doesn't stock many parts for their older yanmar engine tractors. so if ur thinking loader you may have to look aftermarket with a pto driven hydraulic pump .
   / New to me jd 755 has no front hydraulics , apparently a base model, is it worth retrofitting ports and controls #4
jd 755 has No front hydraulics, is it worth retrofitting?
No.
Sell the tractor you have now. Buy a 4-WD tractor with a working FEL.
Loader alternatives:
Tractor Dirt Scoops:
   / New to me jd 755 has no front hydraulics , apparently a base model, is it worth retrofitting ports and controls #5
New member​
Hello friends. I'm new here and I have a couple of questions. I just bought 3.5 acres in Missouri and I'm looking at a 1985 Satoh S650G Bison. It has 6166 hours, inline 4, 3 point hitch, runs well according to the seller, and it's $2750. So, 1) is that a good deal? and 2) Is there a list of loaders somewhere that would fit that tractor with little or no modification? Thanks in advance for the help.
This is a gas engine tractor. 6,000+ hours is quite a lot of use for a gas engine tractor.
Are you adept at troubleshooting and mechanical repairs? Do you have metric tools?
Parts for 40+ year old orphan-brand tractors are very thin.
Can you operate equipment with a traditional clutch and gear transmission? Shop tractor clutch rebuilds are $1,500 in low cost, rural Florida.
Manual steering gets old fast.
2-WD tractors often lack the necessary traction to fill a loader bucket with dirt.
Aftermarket Loaders are available for most tractors. I will guess your cost at $4,500 delivered.
LINK: Front-End Loader - Compact Tractor Aftermarket Loader Suppliers
You would likely need a new, higher capacity hydraulic pump, joystick and plumbing, +$2,000.
Plus labor for installation.
CAVEAT EMPTOR​
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A51694)
2022 Forest River...
John Deere MX 8 Brush Hog, 8', 3pt Hook Up, PTO  (A52384)
John Deere MX 8...
UNUSED AGT SDA-140W WHEEL LOADER (A51243)
UNUSED AGT...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
2016 Mercedes-Benz GL450 4MATIC AWD SUV (A50324)
2016 Mercedes-Benz...
