new to me JD 750: removing steering wheel?
   / new to me JD 750: removing steering wheel? #1
swelltimes
John Deere 750 SCUT with 67 loader
Hi all -
My wife and I recently bought a JD 750 with a handful of implements, from a seller on Craigslist that lives near us.
As anticipated, I'm running into a bunch of issues as I work through the machine and get to know it better.
Need to remove the fuel tank (plastic), to clean out whatever sinister gunk is lingering in there, but to do so, seems like I need to remove the steering wheel.
I borrowed a 3-arm gear puller from a neighbor, and that doesn't work. The 17mm nut on the steering shaft came off easily, and I've been soaking the wheel / spline interface with Kroil.
Before I go buying the wrong new tool, or getting medieval with improvised methods, does anyone have any recommendations as to how to get that steering wheel off?
Thanks!
   / new to me JD 750: removing steering wheel? #2
You need to acquire & utilize a steering wheel puller similar to one pictured below.
   / new to me JD 750: removing steering wheel? #3
I pulled a "simple" steering wheel on an old Ford tractor. Wish I would have had something like Tx Jim shows there. It was a bit of a PITA. But the rust finally gave way and the wheel was pulled.
OK, that's what I figured. Didn't know if there was an easier solution that I was overlooking.
Thanks, @TxJim.
   / new to me JD 750: removing steering wheel? #5
Attach puller then tighten center bolt then tap bolt with a hammer normally steering wheel will come loose from steering shaft.
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2011 Chevrolet Malibu 2LT Sedan (A55853)
2011 Chevrolet...
Cushman Electric Cart (A55851)
Cushman Electric...
UNUSED X-STAR ACS LOADER BOOM LIFT (A52706)
UNUSED X-STAR ACS...
2017 Ford Fusion Sedan (A55853)
2017 Ford Fusion...
