rangerfredbob
Veteran Member
I paid too much at auction, but it was a complete tractor with reverse, only missing one reverse friction shoe thing... The stock knobby tires are even in good shape which was one of the main reason I paid real money...
It had an old rope start briggs on it, don't feel like fiddling with one right now, and conveniently had a Predator 79cc engine on hand ($32 parking lot sale find) which was the right shaft size for the stock pulley. I had to pull the engine plate and drill some holes but I managed to fit the engine under the stock sheet metal, it will need some more massaging to fit better since it catches on the air cleaner housing now... While I had things apart I found two of the bolts holding the bearing in the wobble box of the sickle mower were broken, so I fixed that and greased most of the zerks...
On the reverse shoe I took a HDPE cutting board and cut a shoe out of that with my band saw using another as a template, took the lazy way out and used the band saw to cut a V for the spring, in the 100' it's driven so far it's worked but I haven't used reverse since I haven't gotten a new belt for it yet, they didn't have one when I got the new belts today (took 3 tries on the drive belt, second try on the cutter belt)
Of course now I'm realizing it goes too fast to cut the reed canary grass in it's current state, went to the point of stalling the engine in about 2 feet. With the ground clearance of this thing it will work better much earlier in the season when the grass is under a foot tall, might be under water then but I think this will work...
Pretty neat machine, wish the handles were higher... will raise them at some point. It needs some welding here and there but isn't bad, I'll see about getting pictures tomorrow, might rotate the pull starter so I can reach it without the hood open too...
