Loader New to Me B2710
   / New to Me B2710 #1
greeno
Big Lake
Kubota B2710, Bolens G152
Just drug this beast home this morning. Pretty wicked little tractor. Only thing i can find wrong with it is the "down" position on the loader doesn't work, only "float". Any suggestions?
   / New to Me B2710
Never mind; locked and unlocked the FEL controls and now it works as intended.
   / New to Me B2710 #3
Looks like you have the crew to run it! Nice tractor.
   / New to Me B2710 #4
Great fine :thumbsup: by the looks your not going to get much seat time. ;)
   / New to Me B2710 #5
Tractor looks good but crew looks much better. First and know you will be sure to teach them the dangers. I have a B2710 probably older than yours but tractor only no loader or backhoe. Great little tractor. Think they only came with HST. I have found mine to be hard to crank when cold, will use glow plows even in mild weather for first start of a day. If the headlights are same as mine, at least on when mine was built they did not use true headlights. You can change out the bulbs they use for higher wattage bulb very easy. I have used either 50 or 55 watt bulb which is think same wattage as headlights normally are.
   / New to Me B2710
Trust me, the crew does not operate any heavy equipment without direct (pop’s lap) supervision. Plus, they need years of ground work in order to earn some seat time!
   / New to Me B2710
I always glow my diesels first start of the day; my Bolens takes 30 sec to reach full glow even in the summer.
2016 KUBOTA K008-3 MINI EXCAVATOR (A52709)
2016 KUBOTA K008-3...
2013 Chevrolet Caprice Sedan (A56859)
2013 Chevrolet...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A56435)
2023 Kubota...
1997 Perkins 75KW Towable Diesel Generator (A56857)
1997 Perkins 75KW...
2007 Homemade Pipe Trailer (A55973)
2007 Homemade Pipe...
LOT: (50) 14 Oz. Tubes of Star Fire Multi-Purpose EP 2 Grease (A59076)
LOT: (50) 14 Oz...
