New to me 54 Ford NAA
   / New to me 54 Ford NAA #12
You have not done anything that any number of people have not also done in the past. It is a bit embarrassing to admit but it is a cheap (relatively speaking with the price of gas) fix.
As was mentioned only open the sediment valve 2 turns, opening it all the way accesses the reserve which is about a gallon of gas and also anything residing in the bottom of the tank.
   / New to me 54 Ford NAA #13
I know the tractor is new to you, I would recommend you get in the habit of filling the fuel tank when you get done using the tractor for the day. Two reasons, one, keeping the tank full will help prevent condensation. Two, you will never have to check or wonder if you have enough gas in it when you want to go do something using the tractor.
   / New to me 54 Ford NAA #14
I bought a 54 NAA from a guy a week or so ago and I'm stumped. Tractor fired up, ran around his yard, picked up a 5' Box Blade and drove onto my trailer then stalled out and battery died before getting it started again. No biggie, older battery, had started and stopped a few times so maybe not much recharge time. Already converted to 12V Negative ground so easy enough to figure out if it's charging once I get it started again. Get it back to my new house (4 acres so the NAA is perfect size), throw a jump box on and it fires up just fine. Get it off the trailer, take a quick victory lap and head towards the shop maybe 1000' away to check the charging system and change fluids, etc. before putting her to work. Kick it in 4th, add throttle and it makes it maybe 200' and dies. Won't restart and run the jump box dry. Tow it the rest of the way to the shop and pull a plug (black soot but not wet), getting spark. Grab a tune up kit, change plugs (.025" gap), cap, rotor, points and condensor look new but change the cap and rotor because there's a smudge on the tip of the rotor and I'm already there. No start. Look at the ignition switch and there's maybe 3 strands of wire still connected, A-HA! Replace the switch and still won't start. Give it a little taste of starter fluid to the carb and it backfired... so here I am asking where I should start poking around next. Previous owner also said he put a new, rebuilt head on it recently AND the radiator is leaking from somewhere around the bottom corner near the hose.
Sounds like a fuel problem.
Yeah, it was a fuel problem. I even posted the Carl vid of shame here when I figured it out. :D I've moved on to other problems since then like the alternator being bad (but I have multiple good battery chargers to keep things topped off for now). The new issue is a leaky rear wheel seal pushing out grease needing a new widget to turn the new cable for the new proofmeter... but otherwise she runs well enough to drag a 40 year old bradford pear that fell over last wind storm in a minimal amount of pieces. Also helped to clear 2 acres of weeds with a 4' box blade and get the land relatively level again. Winter is coming fast and I'll get some fresh paint, seals, new alternator and maybe even some 12V headlights for her. The widget worked long enough for me to verify the rpms were where they needed to be on the throttle stop to run anything on the PTO for the meantime.
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A53472)
NEW 2025 Load...
UNUSED LANDHONOR PHA-16-2C HYD HITCH ADAPTER (A51248)
UNUSED LANDHONOR...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
2017 Kubota KX080-4 Mini Excavator (A51573)
2017 Kubota...
UNUSED FUTURE FT-HJ6 HD STORAGE SHELVES (A51248)
UNUSED FUTURE...
TMA (A49461)
TMA (A49461)
